16 posts / 0 new
Last post
plastic penguin's picture
Last seen: 11 hours 59 min ago
Thinking about speaker terminals
Over the weekend the cat decided to recycle its dinner right behind the right hand speaker. I moved it out to clear up and the speaker began cutting out slightly. After wiggling the cable around found the bare ends were shorting out intermittently.
How much would it cost for someone to terminate the cable at the amp end only?
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
Macspur's picture
Last seen: 1 week 6 days ago
RE: Thinking about speaker terminals
Don't know exactly PP, but can't imagine it being that much... I used to have some inexpensive gold plated screw on banana plugs bought from Richer Sounds.
Pussy suffering from the heat too?
Mac
Electrocompaniet EMC1UP, Audiolab M-DAC+, Sonos Connect, Accuphase E470, Harbeth SHL5 Plus, Auditorium 23 SC, HiFi Racks Podium Reference rack, matching LS stands.
Supreme's picture
Last seen: 2 years 10 months ago
...possibly menopause?
Shouldn't that be menopaws?  Smile
Mac
Cheers, mac. I'll give them a bell later.
chebby's picture
Last seen: 2 days 1 hour ago
Any self respecting dealer (especially one you have been a customer with) should be able to solder on a set of banana plugs for an agreed fee. (Usually a tenner* with my lot, or free if I am buying something else at the the same time.)
Don't faff with gold plated exotica. The nickel plated plugs with black and red plastic screw on covers are fine. (Unless you live in a salt mine, gold is ridiculous 'overkill' anyway.)
A good solder job will ensure you never have to go back and trim off oxidised copper.
*A few months ago I bought a lovely pair of JPW Sonatas that had a dead tweeter. I bought a pair of MNIB replacement Audax tweeters and my dealer soldered their connections and fitted them for £10.
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
tomlinscote's picture
Last seen: 2 years 7 months ago
For a tenner you cuuld get a soldering iron and do the job yourself Smile
T
Thanks, chaps. Contacted Unilet this morning and if I get a window of opportunity today I'll nip the cables down. All for a tenner.
T
Thanks for the suggestion. Trouble is I'll use it once or twice and it'll get shoved in the shed and won't get used for another 10 years. By that time it'll probably be rusted or all gunged up.
Eek! I've taken the SilverScreen off and connected up my old Carnival Silver Plus. Fingernails down a blackboard. Honestly didn't realise it was that shrill. :boohoo:
Benedict_Arnold's picture
Last seen: 1 day 7 hours ago
T
The average ten quid soldering iron won't get the plugs hot enough for a proper solder joint and you'll end up with a "dry joint".  If you heat the plugs too much they'll oxidize or tarnish.  That's why a lot of dealers use crimped plugs.
Nothing special Blu-Ray player, Marantz 7010, 7.2.4 with Yamaha NS-IW960, NS-IW660 in-walls & NS-800 in-ceilings, Samsung 6 series 65 inch 4K TV. No stereo worth bragging about.
chebby's picture
When you first got the cable you said it was only a subtle difference.
Have you got the cables pointing the right way for the electrons to flow more easily into the speakers? (If you raise the amp above the speakers this improves.)
Have you burnt them in yet?  (You haven't used them since 2010 but at least the heat wave should speed up the process.)
You could try demagnetising them.
Or drive them to Wiltshire and bury them, for one lunar cycle, near the centre of the Avebury stone circles.  (Roughly speaking, under a tree 10 metres to the east of the house opposite the Tourist Information centre.)  Stonehenge might be better - closer to where they were made - but Avebury is mellower.
CnoEvil's picture
Online
Last seen: 2 weeks 6 days ago
I tried that.............but it only works if on an Equinox. People have tried on the Summer Solstice, but they haven't a clue.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
Yes, connected properly. haven't heard the Carnival for ages, and the last time was way before I purchased the Naim and, possibly, the Leema. It sounds really echoey and nasty.
No. :oops:  Just double checked and it's now been rectified. Sounds better but still doesn't 'right'.
Just got back from dropping the cables off. Little one demanded she came. When we got there she saw a pair of Kef Blades and she ooo'd at their size. She asked how much. When I said around 20k she almost fainted.
Any'sway, picking up Monday as we're off out today.
Log in to post comments
