6 posts / 0 new
Last post
jp1514's picture
Last seen: 3 years 7 months ago
Tech novice
Hello and thanks for having a read.
I have two problems that you could perhaps help me understand. My system is a 90's Technics 1060 model, I was listening to some Neil Young a few weeks ago before heading off to see him live and all was good. The next day I go to play the same tracks and the sound from both original 1060 speakers sounded dull / clouded / muffled / and there is no sound at all coming through the tweeters? Keeping in mind electronics is not my strong point I took the speakers to bits and everything looked OK but still sounded rubbish. So I hooked up a pair of old B&O speakers, unmatched to the amp (100w 6 Ohm amp v 30W 8 Ohm speakers), but they are keeping the sounds coming for now. What has happened?  And while I was hunting for the replacement speakers I found an old Yamaha JA 1801 woofer cone stashed away and I'm sure it used to work but now it wont make a sound at all when hooked up to the Technics amp. I mean Neil Young is still playing so its not the end of the world and I had a bit of Band Of Skulls blasting tonight but I would love to fix these speakers. If you can help out then thanks for any advice or banter. Cheers, jp
jp1514's picture
RE: Tech novice
Sorry about the formating... Or lack of
matt49's picture
Last seen: 1 month 3 weeks ago
RE: Tech novice
Hi jp,
Is there any chance your hearing has been dulled by the live concert? Before making a judgement on your hi-fi, I'd wait a few days. I find that after a live concert my hearing is quite poor.
:cheers:
Matt
Electro's picture
Last seen: 3 days 21 hours ago
RE: Tech novice RE: Tech novice
matt49 wrote:
Hi jp,
:cheers:
Matt
Good point Matt , excessively loud music at a live concert can dull the hearing for a few days and can cause permanent damage .
I go to a lot of live music performances and I always take some musicians attenuating earplugs with me in case the music is too loud .
They give 19 dB of attenuation but do not spoil the sound quality , in fact it makes the whole experience far better usually  Smile .
 Electrocompaniet EMC 1 UP ,  Cambridge Audio id 100 i pad dock, ipad with Spotify premuim, Monarchy Audio DIP, Electrocompaniet ECD 1 dac , EC4.8 preamp , 2x AW180 monoblock power amps , PMC PB1i speakers . Thousands of Cd's .
matt49's picture
I've just started doing the same. I must admit to having felt a bit of a plank at first, but it's worth it to preserve your hearing.
jp1514's picture
RE: Tech novice
My hearing still works after the gig and even after Silverstone two weeks ago.
But the speakers don't  :grin:
Log in to post comments
