Tannoy Revolution DC6T SE Speakers
8 replies [Last post]
L00k_C
L00k_C's picture
Has anyone heard these speakers?
Are they like KEF R500/700/900 in the sense of UNI-Q idea?
Which amps are better match for  these sepakers?
David@FrankHarvey
David@FrankHarvey's picture
RE: Tannoy Revolution DC6T SE Speakers
Yes, they are similar to the KEF's due to their coincident design. They will sound different though, as all manufacturers tend to.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
L00k_C
L00k_C's picture
Not anyone'ss cup of tea?
L00k_C
L00k_C's picture
cheer
Ketan Bharadia
Ketan Bharadia's picture
Online
We're big fans of these Tannoys. They're entertaining in a way few rivals can match. As to what amp works best with them we've had good results with Rega's Brio-R, Cyrus's  6a/8a, Heed's Obelisk, Roksan's Caspian M2. Haven't tried them with Naim's Nait, but would expect it to work well. The choice depends on the flavour of sound you want.
__________________
Technical Editor, What Hi-Fi? Sound and Vision
L00k_C
L00k_C's picture
Thanks Ketan
Can you tell me how they are compared to KEF's R500, R700?
Will CREEK 5350 do with the TANNOYS'
TheHomeCinemaCentre
TheHomeCinemaCentre's picture
I am a big fan as well. If you are looking at the R Series from KEF you would be wise to consider the Precision range  - the next step up from the DC6t-se. The DC6Tse is fair competition for the R500 but for the R700's you would need to consider the Precisions. As always listening in a properly set up demonstration is key.
__________________
Nick
The Home Cinema Centre
L00k_C
L00k_C's picture
Am I wrong in syaing that the only difference between the R500 and R700 is the size of the bass speakers and nothing else?
Why do you say I must UPGRADE into the PRECISION range? Can you tell me, if possible, the difference/what you mean?
Thanks.
eengineer
eengineer's picture
I have my Tannoy dc6t se hooked up on a yamaha micro system (mcr810e) and listening
mainly spotify through a squeezebox classic. No external dac and cheap diy market audio cables.
They work absolutely great!  Voices are so realistic and bass lines so warm, deep and wel defined.
I really can't imagine how a more expensive system will give a more than subtle improvement on what
i've got right now.  I never crank the volume to pain thresshold levels though...
Beth Gibbons, Anthony & the ShlongJohns... It's the music that matters! Enjoy Smile
__________________
