system advice
Sat, Jun 23 2007, 6:42PM
got Mission 780 bi wired spks I want a small CD/Amp/Tuner with facilities to use Ipod which will fit onto my sideboard and look good and still drive my spks.Budget £300ish.I have looked at Onkyo and Teac but I like the sound from my Missions better than supplied spks.
Sat, Aug 25 2007, 11:48AM
#2
Hi there,
You don't have to buy either the Onkyo or Teac systems with the speakers - they're also available just as system units you could hook up to your Missions.
If you could stretch a little to £465.00 you could get a Linn Classik on ebay (http://cgi.ebay.co.uk/Linn-Classik-Music-system_W0QQitemZ230145815745QQihZ013QQcategoryZ4787QQssPageNameZWDVWQQrdZ1QQcmdZViewItem) - which would be a good match for your Missions. Those are good speakers and any 'tiny' budget all-in-one mini won't do them justice... I guess the second-hand is the way to go if you have such a small budget, and Linn Classik seems like the obvious choice...- and you can find good deals on ebay or second hand shops...
If you don't fancy second hand, and would like to go for something stylish, also an interesting possibility would be that Fatman iPod dock - ITUBE, with valves seems like a very classy solution... (http://www.fat-man.co.uk/docs/product/itube_1.htm) - and it only costs 300 quid
Hope this has been helpful...
Razz
