6 posts / 0 new
Last post
tomlinscote's picture
Last seen: 2 years 4 months ago
synology 213j dierct to dac anyone??
RE: synology 213j dierct to dac anyone??
Hi all,
I am sure I have read on here somewhere that the synology 213j can stream direct to a dac and then to an amp with no need for a streamer, anyone know if this is really possible and if so how and do you need any special software or other tricks. And if it is possible is it a reliable way of listening to tunes??
Tommo
stevebrock's picture
Last seen: 25 min 14 sec ago
yes its possible as long as ypour dac has usb
i use DS Audio app to control everything, you just select USB speaker for the output
however Synology still wont do gapless.....grrrr
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
thanks for that  Smile
tommo
ngibbs's picture
Last seen: 1 month 5 days ago
+1.
Doesn't do gapless, but sounds pretty damn fine!
BlueSound Node Streamer, Metrum Acoustics Octave DAC, Pure Sound L10 Pre, Nord One Up Stereo Power amp, Vienna Acoustics Hadyn (study)/ATC SCM11 (kitchen) via Beresford Speaker Switch
+1.
Its my only niggle with the Synology and your right sounds very good via USB into my Rega DAC
Log in to post comments
