Sufficient amp and DAC for LS50?
5 replies [Last post]
Ygate
Ygate's picture
Hi
I ordered the LS50 online after my friend recommended it for me and now I want to buy an amp for it, I am willing to spend no more than a thousand on it but the problem is that I can't audition it nor return.
So far the cyrus 6a and marantz pearl are the two I am looking at. I heard that the cyrus is too low powered so I am not sure if I should get the 8a or if there is something better to consider
I am looking to connect it to a DAC which I will buy later to connect to my PC but for now I will use an Audinst mx1 as a DAC
My room is about 6x5 meters, I listen to most types of music and like a punchy bass if possible
Alfonso
Alfonso's picture
RE: Sufficient amp and DAC for LS50?
Rega brio r and M1 Dac sounds pretty sweet with my LS50s.  Would hit your 1k budget perfectly too...
tonky
tonky's picture
I have heard them with the pearl lite and they sounded great. I also heard them with roksan kandy k2 - also good
but my preference was with the pearl lite
tonky
gregvet
gregvet's picture
I'm sure you could get a second hand 8xpd for £1000. If you aren't going to be able to return it anyway, you might as well minimise any loss if it really isn't what you want (and therefore end up selling it)
the 8xpd is also a great amp for second hand money IMO  Smile
__________________
Bedroom: Sonos ZP90, Cyrus DAC XP+, Cyrus X Power, KEF LS50's
Living Room: Linn Majik DS, Marantz UD7006, Arcam AV9/P7, PMC FB1i fronts, TB2i centre, DB1i rears
BigH
BigH's picture
I'm going to hear them with the Audiolab 8200 cd/amp and Musical Fifelity M3 cd/amp combinations and also try the PMC DB1 Gold speakers. MArantz Pearl Lite KI would be worth hearing if you can, my dealers don't have it in stock anymore.
CustomCable
CustomCable's picture
I know at £1299 it's slightly over budget but the M1 SDAC and the M1 PWR from Musical Fidelity work excellently with the LS50 and you won't need to worry about returning it as you will love it. Smile
Regards
__________________
Phil -  Custom Cable Service and Unilet Sound and Vision, South-West London
