Sub for my hi-fi or save up for a speaker upgrade?
36 replies [Last post]
shafesk
shafesk's picture
Dear all,
I'm once again contemplating what to do with the Mezzos. My amplifier does a good job of driving them but the Mezzos are not the most bassy speakers which I need when I'm listening to the occasional electro. As some of you know I'm slowly saving for some 3000 pound Audio Notes. However, it'll be atleast 3 years before I can justify that sort of outlay. I'm willing to spend about 800 pounds on a musical subwoofer. The most obvious one is the Mezzo 9 but I've heard its not the most musical sub and I would rather get a sub thats good with any speaker. Can you please recommend me a sub to go with the Mezzos?
__________________
Hi-fi:
Denon DNP-720AE network streamer, Mordaunt Short Mezzo 6, Cayin A-55 T, Technics-SLQ210, Denon DP-29F turntable, 540p, Dac-magic, Marantz 5004CD and 6025 Turntable, Mac ,Pure AV interconnects, QED Revelation speaker cables, QED Performance interconnects.
Head-fi:
Akg K702, Grado SR60i, UE Triple-fi, Musical Fidelity X-cans, HRT Music Streamer 2+
shafesk
shafesk's picture
RE: Sub for my hi-fi or save up for a speaker upgrade?
oh comeon, I help out when you have a problem  read this
__________________
Hi-fi:
Head-fi:
DocG
DocG's picture
Hi Shafin,
It's weird, but 'subs in hifi' threads seem to render the forum incommunicado!
http://www.whathifi.com/forum/hi-fi/im-going-active-21
http://www.whathifi.com/forum/hi-fi/music-hifi-subwoofer-needed
http://www.whathifi.com/forum/hi-fi/need-help-with-subwoofer-setup-for-hifi
etc.
Still, I hope you're lucky (I might learn something, too  Wink)
Erik
drummerman
drummerman's picture
I have been using a subwoofer for 2ch for some time. To me, in many ways, its an ideal solution. It allows the best aspects of standmounts (other than ultimate power handling) such as imaging and tight sound whilst giving adjustability and flexibility which you may not have by using a large speaker cabinet which can have their own problems.
Can't really help with which one to buy as mine is not made anymore but it is probably fair to say that huge power ratings dont necesseraly make a good musical subwoofter. Mine is sealed which probably makes it less efficient but the flip side is its nicely tight, fast and integrates well. I have used it with floorstanders to good effect too.
regards
__________________
Pretty ... and pretty proud of it
ID.
ID.'s picture
regards
This is pretty much my experience too. I can't recommend a sub because mine isn't available outside of Japan, but it was a very cheap sealed sub made for music.
__________________
Observe the signature in its natural habitat.
CnoEvil
CnoEvil's picture
Sorry duplicate.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
CnoEvil
CnoEvil's picture
Mornin' there!
This depends.
- How long will it be till you get the ANs
- If you get the sub, how much longer will it add to this time
- How much do you really miss the extra bass
- Are you prepared to compromise with a cheap sub (or it'll take too much of your speaker budget)
- Realize that it takes time and care to get seamless integration
The bigger AN speakers, because of the way they work using the hole room as "part of the speaker", give remarkable bass...and certainly the ones I heard appeared to go lower than my Kefs. This means that a sub "should" not be necessary once you get them.
If you really feel it will be some time before you them and miss the scale, I would look at getting a small, economical sealed sub like the Gemini, or perhaps the XLS 200: http://www.bkelec.com/hifi/sub_woofers.htm
__________________
relocated
relocated's picture
A lot of people have a high regard for BK Electronics and they certainly have plenty of mag reviews.  Direct sales ensure that you wouldn't spend all your money but get big performance.
__________________
Apple Lossless - ATV3 - AVI ADM 40  or  Marantz CD50SE (modded] - AVI ADM 40
also ATV3 into AVI ADM 9T [my wife's system] and Grado SR80i
relocated
relocated's picture
But then you don't seem to be bothered to reply when people DO try to help you.   puzzled
__________________
Big Chris
Big Chris's picture
Sub all the way.
I urge you to try the PV1D. Not heard it myself, but I do have a PV1 and if there are any audible improvements at all over the PV1, which I can't find fault with, the PV1D has gotta be a contender and worth pushing your budget for.  Failing that, you may be able to get a PV1 off eBay for a tidy saving.
__________________
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
bluedroog
bluedroog's picture
Online
I would without doubt put all the money towards speakers, that is not to say you cannot get good results with a sub in two channel but have suitable speakers is almost always the preference.
When suitably paired, well intergrated together and well set up in the room a pair of smaller speakers plus a sub can work wonders but it can also be very hard to get right. If it were a simple yes or no, choose one option scenerio simply getting the most suitable speakers is the wise move, no messing with x-overs and all the other issues that can come with trying to set them up together.
That said if you do want to investigate subs have a look at the BK range because for the value and qulaity they give you can almost try them out of curiousity, not only that but although they might not advertise the fact but because of distance selling laws you can always send it back for a refund. I own a BK XXLS400 and it is spot on, I used it for AV but also sometimes music too, I often turn it off depending on the genre. I crank it up a bit for films and the LFE for music I set it very low for a subtle underpinning of the bass. If you do want a sub look no furhter than BK.
shafesk
shafesk's picture
DocG wrote:
Hi Shafin,
etc.
Erik
Yikes, well I learned somethings but didn't really get recommendations out of them.
__________________
Hi-fi:
Head-fi:
shafesk
shafesk's picture
regards
we are thinking along the same lines about the benefits of a sub then. I would prefer a sealed box too but they seem to be rarer nowadays. Just curious, what sub do you have?
__________________
Hi-fi:
Head-fi:
shafesk
shafesk's picture
CnoEvil wrote:
Mornin' there!
This depends.
Morning to you Cno, as I said it'll be atleast a good 3 years before I get the AN's. If I get a sub then it'll maybe delay the speaker purchase for another 6 months but atleast I won't go insane. To be honest I don't miss the extra bass that much when listening to jazz but only the occasional electro, but I want a setup thats good for all my music. I think I can live with a cheap sub, I think you know that I'm quite handy with placing things (mainly rubber, spikes and foam) so I think I can make the most out of a cheap sub....besides I won't be turning up the sub to huge levels so I'm actually looking for a fast sub which adds just a few ounces of extra punch than a sub in a boy racer's car. Never heard of bkelec before, have you had any encounters with them?
__________________
Hi-fi:
Head-fi:
drummerman
MJ Pro 50 Mk1 (Ruark Vita)
regards
__________________
shafesk
shafesk's picture
My apologies, there is a 5 hour time difference between Dhaka and London. I needed my sleep  Shock
__________________
Hi-fi:
Head-fi:
