4 posts / 0 new
Last post
Hems's picture
Last seen: 2 years 10 months ago
Streaming Setup
I'm thinking about buying a new streaming system but I'm not entirely sure what to go for.  I'm looking for an amp and speakers and will feeding music from my Mac/iPad using optical and/or airplay  (I already have an airport express).  I will also be using spotify (using the iPad).
I was thinking about the Cyrus 6a DAC based on the reviews of the standard 6a as well as the fact that it can be upgraded.  Does anyone have any opinions on this as well as a suggestion on speakers that would suit?
Thanks.
Overdose's picture
Last seen: 2 years 1 week ago
RE: Streaming Setup
Hems wrote:
Thanks.
Depending on budget, I couldn't recommend the AVI ADM9s more highly.
£1250 for amplification, DAC and speakers. The sound is superb. Budget up to £2K would also give you enough for the matching sub and a bit over £3K? would get the ADM40 floorstanders.
Opinions will vary wildly from hereon in, but I'm more than happy with my system.
Juzzie Wuzzie's picture
Last seen: 2 years 5 months ago
RE: Streaming Setup
I stream AEX --> Naim Nait 5i-2 --> Neat Iotas for £1k or so total expenditure and think it is fantastic.  Generally Airplay from one of the many Apple products that litter our flat.  You could do the same with a Cyrus amplifier (or any amplifier and speakers for that matter).
kmlav's picture
Last seen: 1 year 5 months ago
RE: Streaming Setup
The new KEF r series and LS go really well with Cyrus with IMHO the r300's being the pick of the pack unless you have a big enough room for the floor standers.
I am intertaing getting some of those AVI's for my study , not sure I fancy the sub tho. Has anyone got these set up on a desk or wall mounted in use without a sub?
Log in to post comments
