12 posts / 0 new
Last post
lbafsaj's picture
Last seen: 2 weeks 2 days ago
Streamer Advice
Having used my ipod as my main music source, I am now looking to invest in a streamer.   As the rest of my system is Cyrus ( PreXpdQx, 2 x Mono200's),  I have been looking at the Cyrus X2.
I have 2 questions.
1. If I buy a streamer,  does my PC have to be switched on all the time to access the files in my Itunes library.
2.  Is there much difference in sound quality from streamer to streamer.  I see a streamer as a transport device and the sound quality depending on the type of files ( mine are all apple lossless) and the DAC, Amplification and speakers.  So, do I need to spend a grand on a piece of Cyrus kit to match the rest of my units,  or can a few hundered quid work on a cheaper streamer ?????
Cyrus DAC XP+ with Cyrus PSXR.  Cyrus Mono X200's x 2.  Cyrus Stream x2,  Rotel RP855 Turntable + Rega Elys 2 Cartridge,  with Rega Phono MM.  Rega RS3 Speakers. Atlas Interconnects and QED Rev Sig Speaker Cable.
richardw42's picture
Last seen: 1 week 1 day ago
RE: Streamer Advice
1.  Yes you'll need to leave it on, or invest in a seperate NAS drive. Of course services like Spotify make a personal library less important. I guess I listen to 90% Spotify at home.
2. It's really up to you, there's so much choice. Personally I think Sonos is excellent, as it has Spotify, Internet radio and can now access your iPhone, iPad directly. An Apple TV, or Airport Express are viable options too. Have you investigated iTunes Match (it will cope you're library into the cloud to be accessed as you wish.
skippy's picture
Last seen: 3 weeks 9 hours ago
RE: Streamer Advice
+1 for the Sonos.
Like Richard says sign up to spotify or Rdio and you probably wouldn't need to use a NAS.
They have the best user interface out there full stop.
ngibbs's picture
Last seen: 2 months 1 week ago
RE: Streamer Advice
-1 on Sonos.
I've never been impressed at all with the SQ of Sonos, as ultra convenient and user-friendly as it is. I've got one (see sig. below) but I only use it for radio. Very bad match with both my Cyrus DAC XP and Metrum Acoustics DAC imo. On your set up I think you'd really notice its deficiencies.
The streaming function on my Synology NAS drive, however, works superbly well, provided you don't mind the lack of gapless playback and limited radio choice. There's no Spotify attachment on it yet either.
BlueSound Node Streamer, Metrum Acoustics Octave DAC, Pure Sound L10 Pre, Nord One Up Stereo Power amp, Vienna Acoustics Hadyn (study)/ATC SCM11 (kitchen) via Beresford Speaker Switch
p_m_brown's picture
Last seen: 9 months 2 weeks ago
RE: Streamer Advice
Sonos and Nas drive would be my choice and in fact is my main front end at the moment. Given you have a decent dac, I wouldn't worry about the SQ from the Sonos!
Clearaudio, Naim, Audio Physics
Roger_A's picture
Last seen: 5 days 6 hours ago
RE: Streamer Advice
As you use iTunes and already have a good DAC I agree with Richardw42 - don't overlook using an Apple TV (if you want video as well) or Airport extreme if just sound.  Even if you have to buy an iPad/Touch/iPhone to act as a remote you'll still spend far less than a grand and still have a fine system.
Roger
kmlav's picture
Last seen: 1 year 6 months ago
RE: Streamer Advice
Your better off getting a NAS they are really cheap and you will be able to store loads of music.
The cyrus units are really good and will work well with rest of your kit
mitch65's picture
Last seen: 6 months 4 days ago
RE: Streamer Advice
I have to agree, Sonos is a great choice but I found it can be been caught short if your amp and speakers are higher up the food chain which is why I still occasionally use a CD player. A good external DAC should sort this out though......sounds like an excuse for a home demo Wink
Auralic Aries Mini - Marantz SA8005 - Marantz PM6005 - Little Dot Mk.II - Tannoy Revolution DC4T
Sennheiser HD540II - Musical Fidelity MF-200
lbafsaj's picture
RE: Streamer Advice
My main concern is sound quality.    I do see a streamer as mainly a transport device.  Therefore,  will I see any real sound quality difference in buying a Sonos controller for approx  £ 300,  or a Cyrus streamer for a grand ?  Certainly the Dac in my Cyrus preamp is top notch,  so no concerns here.
ngibbs's picture
RE: Streamer Advice RE: Streamer Advice
Personally I would say a definite Yes, you will notice a difference. My experience with Sonos + Cyrus has not been at all good, as I've already outlined. Contrary to what (many) others say, it's a good external DAC that can, in some cases, show up its deficiencies. It's not a question of it 'just' being a transport unfortunatley, there are issues of jitter and other stuff that I quite honestly don't understand, but I do know what my ears are telling me. Have a demo to be sure, but if it's really SQ that you're concerned with, with a system like yours I think you're better off with either a Cyrus Streamer (simple and effective solution) or a decent laptop + iTunes, with a bolted on piece of software like BitPerfect or Pure (more fiddly but possibly cheaper) or the streaming app in the Synology NAS (being free the cheapest of the lot, as long as you don't mind lack of gapless playback, no Spotify app and limited radio). Remember the second hand route via Ebay for Cyrus is always worth considering. Also Sonos won't handle 24 bit downloads, if that's a concern.
matt49's picture
Last seen: 1 month 2 weeks ago
RE: Streamer Advice
The August 2013 issue of HFN+RR carried a group test of streamers, including a Cyrus model. (I'm afraid I don't have a copy of the mag to hand. Back copies are available via the HFN website.) The Cyrus didn't do well in terms of SQ, though make of that what you will. My own view, FWIW, is that £1K for a Cyrus streamer would not be money well spent.
I know you say SQ is your main concern, but have you also considered the user interface? In this respect Sonos is most excellent.
To answer your question, I do think Sonos has limitations in terms of SQ. So the Sonos boxes I use in decent systems (see my sig) have been modded e.g. to replace the cheapo PSU. The SQ of these modded boxes is, IMO, extremely good.
Good luck.
Matt
ngibbs's picture
It's worth adding that I bought my Sonos to replace my CD player (Cyrus CD6SE) while it was being repaired. I was very disapointed with it (as I've already mentioned) and delighted when my CD player finally came back. The CD player has now been superceded by a Macbook Air and the Synology Streaming App (see sig.), both of which sound better than the CD player
Log in to post comments
