21 posts / 0 new
Last post
Michaelholder1's picture
Last seen: 1 year 1 month ago
Stereo Amplifier to match B&W Dm601 S2
Ok so I recently bought a set of B&W Dm600 S2 series speakers with the intention of selling the centre and 603s and keeping the 601s but now I cant decide which ones I want to keep for my Hifi. But anyway, at the moment I am just using them with my old denon micro stack but I want to buy a new amp for them, but i am willing to wait around for good deal.
I want to go used as thats normally the best bang for buck and my price range is £150-200. I have a very eclectic taste in music so the amp would have to be versatile and I would be more partial to a warmer sound as I do like like laid back music. I also listen to a lot of bass heavy music so good bass is good although I have a REL strata which I'd like to connect so a sub out would be useful. Now I have recently posted an forum about bi-amping to get a good understanding of that before I posted this one, so I'm guessing an integrated amp with the upgrade path of a matching power amplifier to bi-amp my speakers would be good. Looks are important but ultimately sound takes priority. Any suggestions will be appreciated; thanks, Michael.
RE: Stereo Amplifier to match B&W Dm601 S2
Peter Kudelstaart's picture
Last seen: 1 month 3 weeks ago
As nobody answers your question I'll give you my penny's worth.
How about a second hand Marantz PM7001 or PM7003? Both have a pre out for your subwoofer en sound warmish. I use a PM7003 in my study and am very, very happy with it. Should also go great with your DM's. Or a NAD320/325. NAD's sound quite cosy too with a deeper bass than the Marantz.
If you want new on your budget the choices ar quite limited, although I'm not well informed about the prices for hifi kit in the UK ( I am dutch). A Yamaha S-500 springs to mind but is just over your budget. This model also has a input for your subwoofer. If you buy new always try to audition!
Hope this helps.
Peter
Set 1: Marantz PM8003, UD5007, Panasonic P42V20, Magnat Zero3 BluesoundNode Set 2: Marantz PM7003, CD5004, Pana BDT500, P42PV70, MordauntShort Aviano2, Node Set 3: Marantz 1060, ProJect usb-dac, MordauntShort Mezzo2, Wharfedale 507.2
Reggie Mental's picture
Last seen: 3 years 11 months ago
Go for this. http://www.superfi.co.uk/p-3285-yamaha-as300-amplifier.aspx
The sub can connect to the speakers.
double post
I hear a lot about NAD amps but I'm never sure which ones are good as theyre often so old its difficult to find out much about them, I'll have a look at the suggested amps. Thanks very much for you replies!
gasolin's picture
Last seen: 1 day 12 hours ago
Marantz PM8005,Marantz CD5005, Rega RP1 Queen LE, Mission LX-2 on isoacoustics 155 stands, Supra Classic 6,HiFime Sabre 9018 USB DAC form my pc with supra biline with supra analog,from my cdplayer to t c electronic dac supra biline xlr to phono
jcarruthers's picture
Last seen: 3 years 2 weeks ago
I had my B&W 601 S3 running with a NAD C320 and it sounded very good.
bluedroog's picture
Last seen: 3 weeks 1 day ago
 The B&W 600 series are not particularly fussy speakers in terms of partnering equipment, they’re a fairly easy drive and have a sound leaning towards the warm side which can be altered to a degree with other equipment to personal taste.
Arcam, Cyrus and Rotel and typically used, Arcam will further enhance that warm sound, I used to run an Alpha 8 with 602s, it lacked in some areas for me, ultimate details and attack but had a sound I know many like. Cyrus tend (perhaps less so their modern stuff) to be on the brighter side.
You could also consider amps form NAD and Roksan.
I even tired a Mini-T from amptastic with my 602s and it sounded terrific, a little harsh over extended listening but better value than Cyrus!
I've heard quite a few people reccommend the arcam alpha 9s, is that a good amp for the price range? Well if they arent fussy speakers what amps in the £150-£200 price range should i be looking at? I do prefer warmer sound, so I have been looking at a lot of Arcam, NAD and Marantz; but in terms of models I really havent much of an idea. I think going older will likely give the best value for money but the problem is its difficult to know what the good models are with the older amps review sites like this only have the newer ones up; also determining how much that amp is worth when matched against newer amps is also very difficult!
bluedroog's picture
The Alpha 9 is a good amp for the price you can pick a used one up for, the 10 again is a considerable step up but the 9 is a sweet spot in terms of value. The 7 is a bit lacking in oomph, the lack of guts paired with a warm presentation just means it sounds far too laid back, the 8 is far better in that it has that bit more drive. The 9 is worth paying a bit extra for is you can find one. The 10 again is a very good amp.
Well I've seen the 9 go for around £100 so thats definitely worth a look at, i saw a 9 plus a matching power amp go for around £150 i think it was which was a great price i just hadnt decided if i wanted that amp at the time. I've been looking about, and one think im stuck with it that i think the case really is a sub, OR bi-amp, cos you cant have both. As i mean, most integrated amps only have one pre-out which id like to use for my sub, but if i wanted to bi-amp id have to use it for a power amplifier. Also the pre-amps ive been looking at only have 2 pre-outs, for two power amplifiers?
bluedroog's picture
You can do both, you just need a sub with hi level output where they share the speaker terminals. Have a look at the BK electric subs.
Ah ok, well I have a REL strata 1 which has a high level input and high level bass cut output. So would i take my speaker cable from my amp, to my sub, high level input, then from my sub to my low frequency speaker?
Lawrie's picture
Last seen: 3 years 3 weeks ago
Hi Michael,
I am considering purchasing the Denon PMA720AE which can be had NEW for £200 and received a 5 star review in last December's Hi-fi Choice.
I am always dubious when buying second hand gear.
Cheers!
Im considering that amp as well, I dont think people pay much attention to denon amps but all the reviews I've heard of them have been really good.
Pages
Log in to post comments
