Standmounters for Naim UnitiLite...
30 replies [Last post]
hone_u2
hone_u2's picture
Hello everyone!
I'm looking to buy standmounters for a Naim UnitiLite (which I can also change since I haven't purchased it yet).
I have a liking towards a sonic character that is transparent, open, agile, natural, rhythmic and balanced. I like a good amount of bass, but I need it to be just right, tight but yet, deep and low. I currently have a Naim Nait 5i with a CD5i, with KEF Q500s and I thoroughly enjoy it. The forwardness, the detail, the clarity and the beautiful character of the vocals really really pleases me!
Now, I'm looking at these standmounters (in order of preference)-
1.) KEF LS50
2.) ATC SCM7 (Haven't ever heard these with Naim, so I don't know how the combination will sound)
3.) PMC DB1i
4.) Dynaudio Focus 160
5.) ProAc Studio 110
I'd want a speaker that is designed or can deliver ideally "the closest to studio sound"...
I might or could go in for the Naim NAP 155XS + NAC-N 172XS, if I can...
I don't doubt Naim's power cause have had a pretty long experience of the current that a Naim can maintain... Just am worried about if the tonal character matches with the design of the speaker... Yes, I still think Naim is a little fussy about pairing, initially they were more, but I think they still are...
Cables are the NAC A5
Coud use all the input that I can get!
Thanks!  Smile
Hi-FiOutlaw
Hi-FiOutlaw's picture
RE: Standmounters for Naim UnitiLite...
I think you have a distinct list, I dare not weave any comment on that list, by the mere fact of only having heard the ATC SCM 7, but I found them with little response at low frequencies, preferred the SCM 11! And my finalists were the Dynaudio Excite 12 and ATC SCM 11.
During my journey in the purchase of my system, I have read many things on the net, and where it appeared Dynaudio, always appeared NAIM!
Seems they are a GREAT/magical combo.
All the best
__________________
LivingRoom
Rega RP3 / Goldring 1012gx # Synology DS213 > QED Performance USB > Rega DAC > QED Performance RCA > Rega Brio R > Supra Classic 2x4mm > Dynaudio Excite X12 and some times BK XLS200 MK II
BedRoom
SBT > G&BL teflon line RCA > NAD 3020i > Supra Classic 2x4mm > Monitor Audio RS1
dragon76
dragon76's picture
I'd say, audition PMC and Dynaudio from your list. From my experience these two brands go very well with Naim.
__________________
Dedicated Win7 Music PC -> Audiolab M-DAC -> Plinius 9200 -> ATC SCM 40; Furutech GT2 USB Cable, Oyaide Interconnects and mains cords; Kimber Kable 8tc speaker cables
hone_u2
hone_u2's picture
All the best
Thanks for your reply mate!
hahaha! I hope Im able to get somewhere with a distinct list...
Yes I did have that concern about the ATCs, but sometimes I feel good amplification remedies the bass response, and makes it more punchy and low...
I have no problems with the Dyns at all really, except especially with the Exites... I felt they were one of the most engaging speakers I've heard in a long time...
Just looking to find if there is something better, after the launch of the LS50s, I was really impressed by atleast what they even claimed to achieve through the monitor "studio like sound"... And I do believe tha Naim and Dyns will go well together, after all, they are both who beleive in pace, rhythm and timing...
What do you think about the PMCs?
hone_u2
hone_u2's picture
Thanks!
I probably will in the next few weeks...
Tell me, do you think the Nait 5i or the one that I'm considering, the NAP 155XS, would lack in power for the PMCs or the Dyns?
ID.
ID.'s picture
I own the PMCs and they havegood bass, for their size. They are also reputed to be a good match with Naim, but I think they are a bit coloured, and somewhat lush to my ears - Not really what you'd call a studio sound.
It all depends on your definition of deep bass and what music you listen to. The PMCs seem to start rolling off around 60Hz, and although you will get some of what is going on at 50Hz, it will be down a few decibels. Seeing as you've been using floorstanders, I suspect that the PMCs won't quite go deep enough with enough slam, let alone the ATCs or LS50.
As I listen to a lot of electronic music, I ended up supplementing the PMCs with a sub. Not needed for all music, but even on some rock music, I found it made a difference in creating a fuller picture.
__________________
Observe the signature in its natural habitat.
hone_u2
hone_u2's picture
Sorry for the late reply...
Wow! Im really surprised you find the PMCs coloured... thanks for the heads up though!
Its hard to explain what I mean by deep bass really, but i despise boom of any kind... I'd like the bass to be in its sonic position and not eating up the rest of the range, several speakers I heard recently, the mid-range just is swallowed by the booming bass... so i'd like the bass to be punchy, tight and rounded.
I think I'll sette in for Naim NAP-155XS and 172 as my pre and power combo...
jockey.wilson
jockey.wilson's picture
Are you actually changing your current set-up?  If so I would suggest that any Uniti product will be a sideways step with no or little improvement for the outlay.  SuperUniti may be worth looking at however, especially if you keep your CD5.  If, you want a streamer then why not an ND5XS with your current kit?
As for speakers, Naim and Dynaudios are a great match and I have used my Contours on two Naim systems over the past 10 years.  They generally require a bit of juice, although newer designs are supposedly easier to drive, but my Contours sounded great on the end of a 45 watt/ch NAP140 power amp.
__________________
Naim NDX / 202 / 200 / NAPSC Dynaudio Contour 1.3Mkii
daramsey
daramsey's picture
Hello hone_U2, and everyone
Hello hone_U2, and everyone else! I'm a frequent browser but first time poster here, I've seen it can get a little heated so please be gentle! rolling on the floor laughing
I often post on other forums, mainly from the pro side as I'm quite a keen amateur home studio user, by which I mean that I'm not brave enough to play my music anywhere else! rockin out embarassed I use some rather serious Genelec 8040a's for this.
The reason for my first post here is that I'm in a similar position to the original poster. My lounge system consists of a Naim UnitiQute which I use to play music from the PC and I've just spent the weekend auditioning upgrades from my ancient Mission 731's which date back to my student days.
My room isn't the largest, approximately 13' x 10' and the speakers sit about 6" from the wall either side of the fireplace. The UnitiLite certainly looks to be a decent bit of kit and if the sound of my UnitiQute is anything to go by should make a great system, presuming the character is similar which I'd guess it is?
I listened to options offered by my local dealer in Brum, they have quite a good range on offer but I won't say the name in case it's against any rules. I'd set a budget slightly below hone's but listened to a good selection and from memory these were my thoughts, remembering my tastes are more monitor than Hi-Fi speaker if there is such a distinction:
1. Focal 806V: Too bright and too boomy, they were a little on the large side but I thought the front port might mean they work well near walls. Didn't seem to. Didn't work for me.
2. Elac BS 243: I was tempted by the heavily discounted price and they had excellent treble but I wasn't convinced by the bass which sounded a little overdone in comparison. Might sound good in a larger room.
3. KEF R100: Very nice and a good size, lovely midrange. Something a little off with the bass again though, a touch boomy and one-note with heavier material. For the size though, very impressive and look good.
4. Dali Ikon 1mkII: Similar to the Elac's, very nice treble, perhaps a little on the bright side but I wasn't convinced with how well it integrated with the bass. These ribbon tweeters seem to be very good in their own right but hard to merge with the other drivers, they make me want to listen to a full-sized panel speaker though!
5. Acoustic Energy 301: I'd not seen these before but the assistant told me they have been very well reviewed recently and that Acoustic Energy design on Naim, I've no idea if this was just salesman talk or true mind you! I found these had the best mix of the qualities I was after, they seemed to integrate very well and had a lovely tight bass but not lightweight with it. It was a huge bonus that my girlfriend felt they were the prettiest of the selection! rolling on the floor laughing I didn't buy there and then as am always keen to research my purchases but the reviews do look good, not seen much talk on them though. Has anyone else heard them?
6. Another speaker which I can't for the life of me remember, total blank. I didn't like it so probably for the best. embarassed
As I said before, this may be a little below your price range hone but it may be worth listening to the Acoustic Energy's if you can't find others that fit the bill. In my opinion they have that studio sound that you are after and I know their other models from the Pro side where they seem popular. I'm tempted to give them a try as well since my Genelecs are also getting a little long in the tooth. I'll keep this quiet from my girlfriend for a while I think. rolling on the floor laughing
Dave.
nopiano
nopiano's picture
The AEs have just been reviewed here: http://www.whathifi.com/review/301
And another magazine gave them 5 stars in their March edition too.  This sector has never been more competitive!
Referring back to the OP, for under a grand, I'd want to hear the new Sonus faber Venere 1.5 too, though unsure how they would go with the Naim sound.  I have heard and liked Naim and PMC, but that was a c £15k system using the Fact.8 speakers.
__________________
Hi-Fi: Krell KAV-300cd, Michell TecnoDec/RB250/Grado Prestige Black1, KAV-300i amp, Transparent balanced interconnects and bi-wire to Sonus faber Concerto grand piano speakers, Nakamichi ZX-7 cassette deck, Logitech Squeezebox Touch, Hitachi FT-5500 and Sony S570ES tuners, BCD Engineering stand, RA Powerlink, Chord powerchord, Grado SR60i cans.
AV: Sony Bravia KDL-32EX503 telly, BDP-S370 player with QED HDMI. Currently unused: Denon AVR-1705, DVD-1710, KEF KHT1005.2
altruistic.lemon
altruistic.lemon's picture
Online
Neat are the classic match with Naim.
hone_u2
hone_u2's picture
RE: Hello hone_U2, and everyone
Dear Dave,
Thank you so much for your detailed reply... It would take me god knows how much time to gather so much info on my own... Thanks for that really...
The thing is, I was only thinking of the Uniti, because of budget constraints... I do definitely prefer separates more than one-box...
I've spent my life around floorstanders and its very hard for me to appreciate the detail, mid-range and bass from a bookshelf unless its very very good... I had really liked my friend's PMC TB2is through Quads... So I added PMC on my list... And so slowly went on to appreciate Dynaudios as well...
My source and power is definitely Naim... whether the XS series or the Uniti, time will tell... or rather my pocket!  rolling on the floor laughing
I completely agree with your speaker reviews of the one's you've mentioned...
Ive personally never liked the Focals... the Diablo's though slightly impressed me...
I really really liked the KEFs R100s, they were phenomenal... I heard them through a Denon 1710AE, and i felt they were lacking in the bass a little too... Although I can't say I felt they were boomy... they are quite fussy about the partnering though I've felt...
Which is why I added the LS 50s... I really really like them!
The only Dali model that I've come to like is the menuet...
And to be honest... i've never actually auditioned the Acoustic Energy's... i would have to find the New zealand dealer...
I'll keep posting my views and findings after Im able to audition some of these...
Thanks again!
hone_u2
hone_u2's picture
Wow! 15k is more than I can even dream of spending for now...
But i would like to know what you think of PMCs lower range... specifically the i series...
Sonus Faber... hmm... could you please post your opinion if you can and tell us what you thought of those...?
I've heard Sonus Faber, toys and stuff... and appreciated them... i felt a slight emphasis on the vocals... Im not sure i can say I liked them really...
Id love to know what you think...
hone_u2
hone_u2's picture
which ones would you say in particular?
Exoticsounds
Exoticsounds's picture
Recently had a chance to try out the Sonus Faber Venere 1.5 speakers and they sounded great, clear and expansive with a nice tight and tunefull bass. Have not heard them with Naim, but as someone else mentioned you should definitely give them a listen.
hone_u2
hone_u2's picture
Now I sure have to!
If I may ask... what source and amp did you hear them through?
