Spendor A6 rake angle?
23 replies [Last post]
Ian64od
Ian64od's picture
Hi
Hi just wondered if anyone has played around with raising the front of their A6s and if so what differences they have noted.
set up: Room is 3.5m x 3.5m. Speakers are 2.1m apart and 2.3m from the listening position.
They're driven by a Cyrus 8xpd qx with an Olive 04HD as the player. ( would also be interested in hearing from users of this combination, Olive analogue out or digital out in to the Cyrus, which do you prefer?)
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
SEE Revolver TT/CA 540/Ortofon 2M Red.
Jambalaya
Jambalaya's picture
RE: Spendor A6 rake angle?
Not yet, will probably try some adjustmentsmthismweekend, I finally got the cables right. I'll post some thoughts.
__________________
Spendor A6, Musical Fidelity M6i and M1DAC, Cambridge azur C350, Denon DP23F, Ortofon Salsa LOMC, Clearaudio Nano, Cambridge Audio iD100 dock, MIT CVT 1 Pro balanced interconnects, Alpha Core Goertz MI2 Veracity speaker cables
Ian64od
Ian64od's picture
I got the idea from someone else while I was trying out some Kef R500s. (Rejected these in favour of the A6s)
Compared to my sitting position the A6 mid/bass driver is a bit low. Given that the crossover frequency is relatively high on ths driver I thought that firing the signal up a bit might help, it certainly hasn't made it worse.
I have a small amount of toe in too.
Ian.
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
omnibeard
omnibeard's picture
Stick them on a couple of breeze blocks each to see if that makes a difference, and go from there.
Having said that, my builder friends tell me there is no such thing as a breeze block - they are either concrete blocks or something else.
Sorry, not being terribly helpful am I?
cse
cse's picture
[/quote]
No you're not. You only sound extremely annoying!
__________________
Jambalaya
Jambalaya's picture
The spikes that came with the A6's are adjustable. My dealer recommended a bit of break in before I tried it so after about 3 months I figure its time. I'm going to do some fine tuning left to right and with up down angles.
__________________
omnibeard
omnibeard's picture
OK poppit, have a nice week!
gregvet
gregvet's picture
Have you been taking lessons frmo Drummerman there omnibeard?  Wink
__________________
Bedroom: Sonos ZP90, Cyrus DAC XP+, Cyrus X Power, KEF LS50's
Living Room: Linn Majik DS, Marantz UD7006, Arcam AV9/P7, PMC FB1i fronts, TB2i centre, DB1i rears
omnibeard
omnibeard's picture
I don't need lessons, but he is a great teacher!
I have to say though that I was being totally serious... try raising the speakers to see if that makes a difference - I have raised floor standers before, by a tiny amount, and found that it made a positive difference. It might be breeze blocks, it might be something else, but it's worth trying.
Apologies if that makes me sound arrogant or annoying.
Actually, no apologies.
Ian64od
Ian64od's picture
Be interested to hear how you got on Jambalaya.
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
Thompsonuxb
Thompsonuxb's picture
I raise the front spikes onto jenga blokes so the speakers lean back...... I have not set them flat for quite some time, will try it see if it makes a difference....lol (although a few manufacturers are doing it now)
Ps I have 'inverted speakers' mid bass driver above tweeter, I think thats why I did it in the 1st place
Jambalaya
Jambalaya's picture
I experimented today, not long, for about 15 minutes, raising the front bottom edge up about one half inch but with DVD cases which took the front spikes off the floor.  Seemed to open up the vocals of Diana Krall a bit and the soundstage was larger.  I will take more time this weekend and do it properly by raising the height of the spikes, then will post more. Have a great weekend!
__________________
respe
respe's picture
its not particularly the rake angle you need, or at least it was not in my system. I found I had better results by lifting the speakers so that the tweeters are just below ear height when sitting listening. Two granite chopping boards under each speaker sorted it.
Ian64od
Ian64od's picture
Hi, thanks for that recommendation. Presently I'm happy with the front spikes lifting the speakers. I'll see what I can do and give it a go. Where did you get the granite from?
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
respe
respe's picture
B&Q or Tesco I think, just Granite chopping boards stuck together with a bead of mastic. Makes it easire to slide them around till you have the toe in etc as you want it. I then get some felt pads and stuck them to the granite under the spikes.
cse
cse's picture
There you go again, you just can't here yourself can you.
__________________
