Specific speaker advice please
12 replies [Last post]
made_in_womb
made_in_womb's picture
Hi ,
Their is such a huge choice out their of speakers.So I'd thought I'd ask a few questions that are more specific for my requirements to narrow my search .At the moment I have some Bookshelf, active  monitor speakers .I use them for music production and general listening . My current speakers,Whilst for monitoring are fine ,do not give much bass depth .In-fact most of their sub base comes out of the back portal .I'd like something a little more that can be felt .
So I thought I'd look into some more fun HI-FI floor standing speakers .I listen to electronic/house/dance styles of music. so a well controlled ,deep bass production, is essential .
My budget is approx £200-350 .I don't mind buying second hand or new .They will be in a room of approx 4 meters by 5 meters .At the moment I don't have a amp ,so I think I will first find the speakers, then I'll buy a amp to power them .
So, I'm basically wanting some fun sounding speakers, that are noted to have a Good lower end reproduction for Electronic genres of music .
Thanks in advance for any help guys Smile
Quest
David@FrankHarvey
David@FrankHarvey's picture
RE: Specific speaker advice please
As far as quality is concerned, most standmount type speakers will outperform equivalently priced floorstanding ones, and even then, at this sort of price level, it will depend on just how good you want them to be.
There are very few floorstanding speakers in this price bracket, and those that are will unlikely bring anything to the party that you're going to enjoy. I think your better option will be to add a sub, but again, sub quality in this price bracket isn't going to be studio quality, so again, it'll depend on your requirements and expectations.
I think at this point you will have to decide whether you're going for bass quantity or accuracy. Both come at a price.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
AlmaataKZ
AlmaataKZ's picture
why not just add a sub?
Overdose
Overdose's picture
Online
+1 for the addition of a sub as per the two previous comments.
What do you currently have? Is there a matching sub by the same manufacturer that might integrate well?
__________________
Mac mini > AVI ADM9Ts
Blackdawn
Blackdawn's picture
You could try some Tannoy V4's, Q acoustics 2050 or i model, Acoustic energy neo 3.  All had good reviews.
__________________
HiFi- Cambridge Audio 340C- Pioneer A30- Boston Acoustics A26 speakers. Denon FM/AM. Pure DAB.
Marantz CD6004 - Beyerdynamic DT250
made_in_womb
Yes a sub would be fine provided it will match ok with my monitors.If I remember correctly they are m-audio monitors(check when im home).They have a built in amp .The only outputs from the main speaker are for the left hand speaker and a headphone output(which mutes the speakers when plugged).The source is from my pc's audio card.So what would be the best configuration to match a sub?.
Overdose
Overdose's picture
Online
Usually the sub will have throughput connections that allow the signal to pass to the monitors untouched, this preamplified signal can then also be used for the sub and is filtered to set the sub up according to your room and your speakers.
Have a look at the manufacturers recommendations for sub setup with your speakers, failing that, pop into your local proaudio shop and ask for advice.
There are plenty of subs around at your budget, but your money will go further in the second hand market.
__________________
made_in_womb
whoops
made_in_womb
Yes a sub would be fine provided it will match ok with my monitors.They are m-audio studiophile av40 speakers.They have a built in amp .The only outputs from the main speaker are for the left hand speaker and a headphone output(which mutes the speakers when plugged).The source is from my pc's audio card.So what would be the best configuration to match a sub?.
Overdose
Overdose's picture
Online
http://www.dv247.com/studio-equipment/m-audio-sbx10-powered-studio-subwoofer--68397
Give these guys a ring, they might be able to help with this m-audio sub.
__________________
made_in_womb
Sorry for the double posts !.
Thanks guys for clearing up some issues . Especially that I can get a sub with a' pre-amp out' to feed to the monitors .
http://www.dv247.com/studio-equipment/m-audio-sbx10-powered-studio-subwo...
Looks like those should do just the Job party time! .
Overdose
Overdose's picture
Online
Do let us know how you get
Do let us know how you get on.
__________________
lindsayt
lindsayt's picture
Try a pair of Goodmans Magisters for £30. They will give you the decent bass that you crave. You might want to check that they are fully working when you collect them from Bornemouth. Then all you need is a super little Japanese amp to go with them. Something like one of the 2nd hand Sony ES integrateds for about £150.
