Speakers- to toe or not to toe? That is the question!
28 replies [Last post]
nicholasc1585
nicholasc1585's picture
Ok, I’ve been pondering this for a while. The question is……<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comshockedfficeshockedffice" />>>
Apart from Mission, have you ever come across hi-fi speakers that were not improved sonically by the application of some degree of toe-in positioning?>>
All things being relative, I profess to being a moderate hi-fi enthusiast [:$]. Over the past 25 years of pursuing my enthusiasm, (Missions apart) I don’t ever remember reading or hearing a speaker that didn’t appear to sound better with a toe-in position. >>
Now, I have been amazed by the knowledge and experience of members of this site regarding speaker makes and models; some are truly encyclopaedic! [:D] So to scratch this little itch, I’m genuinely interested to hear if any of you have experienced the above.>>
Cheers,>>
Nick>>
SteveR750
SteveR750's picture
Re: Speakers- to toe or not to toe? That is the question!
I cant make my mind up what (if any) is the best amount of toe in. moving only a few cm on my sofa has more effect. Toe in looks ugly too.
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
jaxwired
jaxwired's picture
I agee with Steve wholeheartedly that toe in is ugly.  Love the symmetry of straight firing speakers.  However, I do toe in all my speakers.  I think they image better.   Some speakers that are on the bright side probably benefit from zero toe in.
__________________
iTunes Lossless -> Airport Express -> Benchmark DAC2 HGC -> Belles 150a REF V2 -> Dynaudio Focus 340-> Chord Cables
Tom Moreno
Tom Moreno's picture
Don't speakers with ribbon tweeters ussually recommend zero toe-in? I know Dali recommends that no listening position should be 100% on-axis because of the ribbon HF driver. Does Monitor Audio offer similar guidance on their platinum range?
__________________
Denon AVR-3808A, MA RX6, BX Centre, BXFX, BX2 (rear surr), BX10, Sony KDL-40W5500, Oppo BDP-83 MR, Sky+ HD, Xbox 360, QED MDH6 Mains Filtration.
David@FrankHarvey
David@FrankHarvey's picture
Spendor. They like to work pointing pretty straight on.
With most speakers, it's personal preference. Toeing in too much can rob the system of width, and not enough can end in a lack of central image. It really is trial and error in most cases.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
Gusboll
Gusboll's picture
I agree about Dali's. My old pair of Suites had to be facing directly forward; any toe-in killed the sound.
__________________
Cyrus 8vs2 (+ PSX-R), Cyrus X Power Amp (+ PSX-R), Squeezebox Touch, Silver High Breed Quintessence Cables, PMC FB1i Speakers.
Hi fi is for Life
scene
scene's picture
As with most things in the audio world, it depends. It depends on the speakers (rear port boominess can be reduced by toe in, stereo imaging can be tweaked), it depends on the room, it depends on the placement of the speakers in relation to the walls (speakers near side walls can benefit from toe in as it reduces side reflections), it depends where you are sitting in relation to the speakers and, finally, and probably most importantly, it depends on personal taste.
I've got my monitor audios toed in about 7-8o and I think they sound great. In my previous house I had them dead square, and preferred that. Same speakers, same listener. Room geometry and size change.
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, Sonos ZP90, AE Compact-1.  AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A.  2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90.  Cables: That Cable HDMI, Chord Crimsons, CAT6 backbone  Sonos S5s in the bedrooms
ifitsoundsgoodl...
ifitsoundsgoodlistentoit's picture
I have experimented with my T+A's and found that having them firing straight forward results in the best sound. cant say if this is typical of all T+A speakers though...
audioaffair
audioaffair's picture
Many speakers are more effective in your "average" living room when toed in. Having said that there are room considerations to take into account and more often the exception to this rule is electrostatics. Experiment a little for yourself and find a position you prefer. If you have to state a rule of thumb for this, generally a good position for many speakers is in a triangle or slightly elongated triangle with the speakers pointed almost at the listener.
Its also really worth considering some level of acoustic room treatment. It isn't practical (or sometimes permissable as I've found Wink) in many living rooms to put massive sound traps in all corners of the room etc, but even something as simple as a few Advanced Acoustics panels on the wall (some of which can be wrapped in an image and simply look like a canvas) can make a massive difference in absorbing sound waves where necessary to avoid unnecessary deflections and echo if present.
It takes some time and experimentation but this is an often overlooked aspect of system sound that can can have big benefits.
__________________
Maurice (Store Manager)AudioAffair, now including Faithful Audio
SteveR750
SteveR750's picture
FrankHarveyHiFi:
Spendor. They like to work poiting pretty straight on.With most speakers, it's personal preference. Toeing in too much can rob the system of width, and not enough can end in a lack of central image. It really is trial and error in most cases.
Hmm, mine are toed in at around 20 degrees at a rough estimate. They are firing across my lounge which is not very deep - all of about 6ft from my listening position, and about 5ft apart. I found the imaging to be slightly improved in the very small 'hotspot'  They have been like that for a while now - I am going to experiment again!
__________________
catlike
catlike's picture
I have a lot of toe-in with my rear port floorstanders, helps with keeping bass under control at higher volumes.
I got over the "look" thing, it seems I am the only one that notices.
 edit: just saw steves post and I think mine are around 20 degrees as well
audioaffair
SteveR750:
You should be able to get the "sweetspot" or "hotspot" but toeing in the speakers a little - not quite in a triangle into the hotspot but almost all the way in works well with some speakers.
Still can be very room and speaker model dependent which is why some experimentation is a must.
__________________
SteveR750
SteveR750's picture
Hmmm, ok they are now firing "straight". Imaging is less seat position dependant, and the bass has reduced, but I had to move them further away from the wall, now at least 2ft away from the rear wall, and about a 1ft either side of my protruding hearth / fireplace. Don't mind the loss of bass, as I have a papier mache 3rd party wall with my neighbours.
__________________
DavieCee
DavieCee's picture
Mine are around 5 feet apart, 18" away from back wall & toed in around 10-15 degrees (pointing just behind the listener). Any more gives more focus but less soundstage and vice versa. I don't have to worry about listening position as I always sit in the sweet spot and no other listeners in my digs.
bretty
bretty's picture
straight-firing for mine. Treble-heavy with toe-in.
__________________
GyroDec SE (Lil' Video) - TechnoArm A - Grado Reference Platinum 1 cart
Rotel RCD-991 - Exposure VII Pre amp (Dual Mono) - 2 x Exposure VI PSU - Exposure Super VIII Power - Rogers Studio 1A
Optoma HD33 projector - 106" screen - Sony STR-DA1200ES - Tannoy Eyris Surround Package - REL Strata II
steffy72004
steffy72004's picture
From personal experience changes with speakers models. Previously with Tannoy and Acoustic Energy I had the best results with toeing in directly at my ears, on the contrary now with Rega I use them almost firing straight, with very slight toe in.
__________________
Analogue: Ariston rd11s, Heed Orbit 2, Esoter Track Fifty arm, Benz Wood L2 cartridge
Digital: Rega Apollo, Musical Fidelity Vdac II + Vpsu
Amplification: Primaluna Prologue 2 with Gold Lion kt77
Speakers: Rega Rs5
