Speaker wire for Nad C326BEE and Monitor Audio Silver RX6
Hi to all, according to you what is a good cable, under 30€ mt, for my system?
Some one suggests me to buy Van Den Hul CS-122 Hybrid. What do you think about?
And what is the difference between this wire and Van Den Hul D-352 Hybrid?
Thanks.
Thank you. I have a room large 55 sm. Do you think I should change my amplifier and use one with more Watts?
Hi consenso
Your welcome.
Only if the C326BEE is running out of steam.
All the best
Rick @ Musicraft
I was thinking maybe with a room larger than last one I need a larger amplifier in watts.. thank you.
When I was shopping in Hifi store the assistant told me Monitor Audio had left him a reel of Monitor Audio Pureflow silver cable. This appears to be the same cable used internally in their recent speakers. I've been using the cable to bi-wire GX50 from a Cyrus 8xpdQX for over a year and it is very good.
Do you think if I will change my NAD C326 for a Rotel RA-1520 should be a good upgrade?
Hi consenso
Also try the NAD C356BEE or if you are happy to consider used/discontinued amplification then Rotel's RA-1962 and the NAD C370.
All the best
Rick @ Musicraft
I just have a chance to buy a Rotel RA-1520 for 450€ (used but still on warranty) do you think it is a good chance or better to wait and then do a real upgrade?
Hi consense
Save your money and go for an RA-1062 instead as the RA-1062 will form a far better tonal match with Silver RX6's
All the best
Rick @ Musicraft
- Login to post comments
Thanks.
Hi consenso
I feel that 79 strand OFC or at a push 500 stand OFC type will be more than good enough for your C326BEE amplifier and Silver RX6 speakers. Fwiw, i also only use 79 & 500 strand speaker cables with Monitor Audio's Platinium PL200 and PL300 speakers.
All the best
Rick @ Musicraft
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all
