3 posts / 0 new
Last post
mikemcspoon's picture
Last seen: 3 years 3 months ago
speaker advice/opinions sought
hi
need advice on the following please.
should i buy a sonos s5 or a connect amp and use monitor audio ct265 idc
ceiling speakers.
its for a kitchen in a bungalow room size 4ish x 5ish m.
any opinions or experiences on the ceiling speakers would be handy as
i have never used any before.
living room . solo neo monitor audio silver rs1. love the neo.
thanks in advance.
plastic penguin's picture
Last seen: 11 hours 54 min ago
RE: speaker advice/opinions sought
Welcome...
I've no idea about ceiling speakers or Sonos. FWIW, IMO you'll be better off looking at traditional speakers, as the ones I've heard in shops so on and so forth tend to be less than great, but my knowledge of ceiling speakers is a little thin. Like anything it could depend on your budget.
Seeing as you have a Arcam Solo Neo, it'll need better speakers than the RS1s. I'd still stick with MA but look at RX1 or GX range. otherwise, I'd look at Focal 806V, PMC DB1i or B&W 685.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
hi
thanks for the reply, very undecided about the ceiling speakers but interesting advice re the rs1. i will look into that and may upgrade.
thanks again
Log in to post comments
