7 posts / 0 new
Last post
admin's picture
Last seen: 3 days 17 hours ago
Sound problems: Turntable to Marantz PM6004
Hi all, new to the site and forum Smile . I bought the Marantz PM6004 about a month ago and started using with a Soundlab GO56C turntable (as well as a CD player). The sound wasn't coming out of the right speaker at first but then started to work (don't think I really did anything!). Has been fine until today when the same problem has reappeared. The CD player works fine still.
Unsure what the problem might be. Could it be that the turntable is incompatible with the amp somehow? On a separate note, the turntable doesn't have a ground wire but this might be irrelevant.
Can anyone help as I'm unsure what to do to solve the problem
Thanks!
PAULCHRISTOPHER's picture
Last seen: 5 months 3 weeks ago
RE: Sound problems: Turntable to Marantz PM6004
Hi not talking as an expert but I recently bought a Marantz PM6004 & CD6004. & Q Acoustics 2500i speakers. I am using this wih a Technics SL-BD22 turntable. This has a grounding lead which is designed to reduce hum. The absence of such a lead would not stop the signal from the cartridge which should be a MM (moving magnet) cartridge .I understand that the PM6004 would not support a MC ( moving coil ) cartridge - the output would not be enough. If you have intermitant output from one channel on the anplifier then it looks like you either have faulty connections or a faulty amplifier. This has overload protection but this would result in a total shutdown. It looks like poor connections to me
chebby's picture
Last seen: 1 day 18 hours ago
There is a switch at the back of the turntable called 'Phono Line'. (It's next to the USB output.)
I think this is supposed to be switched to 'Phono' when connecting to the 'Phono' input on your amp (and 'Line' for an amp without a dedicated 'Phono' input).
There also appears to be a GND terminal on your deck.
Try connecting a ground lead (any thin bit of insulated wire) between that and the GND terninal on your amp.
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
Anonymous's picture
Thanks for posting replies both.
I definitely have the 'Phono' switch on - it's been working fine for a month and I haven't changed anything. Interestingly, my turnatable is different to the picture as it doesn't have a GND connection.
I can only imagine it's the amp (probably out of warrenty now) as I tried a cable that was connecting the CD player and it was the same when connecting to the turntable.
An odd problem for sure!
chebby's picture
Steve_01 wrote:
I can only imagine it's the amp (probably out of warrenty now)...
Out of warranty after only a month?
Steve_01 wrote:
Hi all, new to the site and forum Smile . I bought the Marantz PM6004 about a month ago...
... or was it second hand?
Anonymous's picture
Chebby - sorry about that, it was bought new, not sure where I got that warranty comment from!!!
Anonymous's picture
Update (in case anyone has the same issue)
Problem solved by reconnecting the cartridge on the turntable - it seems a dodgy connection (as suggested above)
Hope this helps someone in the future.
Log in to post comments
