SONY BDP-S790 - New To Blu-ray, Help Needed!
11 replies [Last post]
ChesterG
ChesterG's picture
After holding out for a few years I've decided to finally invest in a blu-ray player. I wanted to stick with Sony hardware (my Sony DVP-NS300 DVD player is still going strong after 11 years with no problems whatsoever) and after a bit of research I've decided to get a BDP-S790 but as a complete newcomer to the technology I wanted to ask the forum's advice on a few points which would help me a great deal:-
1. One of the essential requirements I have is multiregion playback of DVDs. If I purchase a player which is already hacked (through amazon for instance) would this affect the warranty?
2. There will be occasions when I'll want to use the player with an "old-style" cathode ray TV with the usual scart & Video/Audio-In connections, but is this possible?
3. In order to play SACDs through the S790 how should it be connected to my Rotel 1520 amp?
Any help would be much appreciated.
__________________
Rotel 1520.....B&W 684.....Arcam CD192.....RPM4 Turntable
Sizzers
Sizzers's picture
RE: SONY BDP-S790 - New To Blu-ray, Help Needed!
1: They’re not hacked. Personally I would buy from here: cheaper, and better after sales service should things go wrong.
2: Yes. There are HDMI-to-SCART converters available but I have no idea how they may perform.
3: Through the analogue outs.
__________________
Putting out fire with gasoline
gel
gel's picture
Online
Personally I would buy it from RGB, £200 plus the Spidermans and free multiregion upgrade, can that be beaten?  I don't think so.   Cool
__________________
Panasonic 50GT50, Pioneer Bdp-lx71, Pioneer Vsx-lx70, B&W FPM Series & B&W PV1.
ChesterG
ChesterG's picture
Sizzers wrote:
1: They’re not hacked. Personally I would buy from here: cheaper, and better after sales service should things go wrong. 2: Yes. There are HDMI-to-SCART converters available but I have no idea how they may perform. 3: Through the analogue outs.
Thanks for the info Sizzers! With regards the machines being hacked I was thinking of buying through Marketplace where there are a few companies offering this. I'll also check out the HDMI to SCART converters you mentioned. I know there'll probably be a drop in quality when I have to use this, but needs must. :)
__________________
ChesterG
ChesterG's picture
That's certainly the best deal I've seen for this player but I've not come across RGB before. Are they a fairly mainstream company?
__________________
gel
gel's picture
Online
Yep, the name is RGB Direct, and they were named retailer of the year last year.  I have purchased from them before and they were very good.
__________________
ChesterG
ChesterG's picture
RE: SONY BDP-S790
OK, thanks!
__________________
ChesterG
ChesterG's picture
SONY BDP-S790 Help Needed!
I've gotten hold of a HDMI to SCART box but I'm having some problems. R2 DVDs play OK but Bluray discs and R1 DVDs have juddery movement when characters are in motion or when the camera pans across a scene. I assume it's either the box (which would be odd as the R2 discs are fine) or there are some settings on the bluray player that I need to change. Has anyone encountered similar problems when using an old-style TV or got an idea what might be causing the problem? (playback on the flat-screen HDMI ported TV is fine).
__________________
Sizzers
Sizzers's picture
RE: A Shot In The Dark?
How as your post ended up here??!! lol
Although I pointed out that there are HDMI to SCART converters available, I did state that I had no idea how they might perform (get out completed!) I don’t understand why you’re trying to play Blu-ray on your CRT, though: you said that you only wanted to play DVD’s on it.
Off the top of my head in “Screen Settings” you could try changing the “Output Video Format” settings to 480i/576i, and under “BD/DVD-ROM 1080/24p Output” set that to “Off”. I have no idea if this will actually work , but I’m full of a stinking cold and it’s the best my addled brain can think of at the mo.
Good luck!
Edit: What is the make/model of the TV.
__________________
Codex77
Codex77's picture
You can buy legitimate multi-region versions of this player through Richer Sounds.  I know because I bought one myself, a couple of weeks ago.
__________________
Sony Bravia KDL-46HX853 3D smart TV, Yamaha RX-A2010 AV receiver, Monitor Audio Silver RX6 floorstanders, Monitor Audio Silver RX Centre, Wharfedale Valdus 100 SE bookshelf speakers (surrounds), Sony BDP-S790 blu-ray player, Sony Playstation 3 (500Gb).
ChesterG
ChesterG's picture
RE: A Shot In The Dark? RE: A Shot In The Dark?
Good luck!
I intended to play bluray discs on it but it also had to have the ability to play multiregion DVDs to make me fork out for it. I'll try making the adjustments you mentioned and see if I can produce any changes. If the worst comes to the worst I'll ditch the old telly (a Toshiba 1450TB) and upgrade to a small modern LCD screen with HDMI inputs and then sell the converter unit.
PS. Hope you get well soon. Smile
__________________
Sizzers
Sizzers's picture
Well there is absolutely zero out there on your particular TV.
Perhaps it doesn’t like/accept 60hz but I have no way of confirming this. There are CRT TV’s many years old which do happily play NTSC discs, but perhaps your’s isn’t one of them.
Again, good luck and hope you get it sorted
P.S Thanks for the "get well" but I still feel like s***! lol
__________________
