Sonos - Still a good buy?
31 replies [Last post]
bigblue235
bigblue235's picture
Hi folks,
I'm currently trying to work out what to do for home audio. Had a recent change of home, so going for a new system too.
I thought Sonos was a no-brainer, but the more I think about it, the more I'm going off the idea.
bigblue235
RE: Sonos - Still a good buy?
Errr, half of my initial post seems to have disappeared, and I don't seem to be able to edit it for some reason? Can't edit that typo in the title either! I do seem to be able to edit this one, so I'll try again!
I was basically just wondering what makes Sonos worth the price? It seems to me to be expensive compared to some of the alternatives. I'm also a bit puzzled why the Connect/ZP90 is more expensive than a Play:3?
For the £279 it costs for a Connect, I could buy a laptop or desktop PC, a PS3, or even a small TV with USB/DNLA music functions. All of those things do so much more for similar money, so what makes Sonos special? Is it the sound quality?
My girlfriend seems to think that another PS3 or two is the best idea and, as much as I like the Sonos system, I can't really argue. It plays CDs, BDs, has catch up TV, DNLA, etc. The only benefit I can see to Sonos is streaming from a NAS, which means it's better for my purposes than the likes of Apple TV, but with a PS3 or PC I could store music locally on each device.
What do you say, Sonos fans? Convince me!
mykspence
mykspence's picture
RE: Sonos - Stil a good buy?
Sound quality, ease of use, expansion.
__________________
ZP90 > SIA2-150 > SCM11
The_Lhc
The_Lhc's picture
Nothing works as well or as easily as Sonos and absolutely nothing does perfectly synced multi-room anywhere near as well. That said if you're only after one room there probably are cheaper alternatives.
The pricing is a historical thing, when the ZP90 was released it was the cheap box but Sonos realised that they couldn't price the Play:3 above it, given the competition it would be going up against. The ZP90 is far more flexible in terms of inputs and outputs however and gives upgrade options (such as using an external DAC for example).
__________________
No signature worth mentioning...
bigboss
bigboss's picture
This was my exact question a couple of years ago. The thread makes an interesting read. I went for the Sonos ultimately, & couldn't be happier. Check the thread:
http://www.whathifi.com/forum/wi-fi/why-is-sonos-so-expensive
In theory, PS3 in every room sounds like a good idea, but for it to work, you'll have to switch your PS3 & TV on every time. I can start music in any room any time I want, just sitting in my bed!
Play:3 & ZP90 have specific purposes. I had the same question for ZP120 vs S5 (now known as Play:5). ZP90 connects to your existing Hi-Fi which is most likely to have better speakers than the tiny single Play:3 & you can listen to stereo with one device.
__________________
My Home Cinema  Pioneer KRP 500A, Yamaha RX-V1900, MA Radius R225HD LCR, R90HD rears, AW12 sub, Panasonic BD60, PS3, Sky HD, Logitech Harmony One, Logitech PS3 Adapter, Sonos ZP90
professorhat
professorhat's picture
For me, firstly there's the extremely simple setup - literally plug in, hold down a few buttons and then they're all talking to each other. Second, once setup, this allows music to be played in multiple rooms - either different music / sources in different rooms (so my girlfriend can have Radio 4 in the kitchen whilst I listen to my favourite track in the lounge), or the same music synchronised in all rooms at the same time - great for parties etc. Couple that with the ability to stream any music from my Mac, my NAS, internet radio or any of the music available on Spotify (with the Premium membership) and control it all from our iPhones.
You can also hook up a source to the line in socket and then have that play in another room e.g. I've connected my Freeview PVR up to the Sonos in the lounge and that allows me to stream music from this into the kitchen, so I can walk in, make a cup of tea and still hear what's going on with the TV.
It seemed like a lot when I purchased the two ZP90s, but I instantly fell in love with it and don't think it will be long before I install a Play:3 in the bedroom.
visionary
visionary's picture
It just works!
If it matters to you, I believe it's also the only product of its type that will play Apple lossless.
With a ZP90/Connect, you could play a CD that a mate brought round and use the ZP to feed it back into the system for listening in multi zone without having ripped it.
Multiple control options. Excellent sound quality
Wouldn't go back!
__________________
Sonos ZP90>Missing Link "Digit">Dacmagic>Chord Chameleon Plus>Leema Tucana I>Van Damme UP LC-OFC>ATC SCM40s
bigboss
bigboss's picture
It may be worth waiting for this, as this might trigger a price war:
http://www.whathifi.com/news/google-plans-affordable-multiroom-music-system
__________________
Andy Clough
Andy Clough's picture
Don't know what happened there, but I've edited the title for you.
__________________
Andy Clough is Editor of whathifi.com
franklin2829
franklin2829's picture
Everyone has pretty much answered this but I would add that the technical support sonos provide is second to none and the regular online updates are brilliant and keep it current. Sonos for me!
Chris
__________________
Chris Sullivan
Director at Pixll
nads
nads's picture
or you can basically do the same with the Squeezeboxes for less.
__________________
Not a HiFi Nut. Just has a pile of Nads.
The_Lhc
The_Lhc's picture
Except you can't. For one room, and if you have a NAS that can run the software, fine but any more than that it just won't work as well and won't work at all if you have rooms out of range of your wireless router. And if the rumours about Logitech's lack of interest in Squeezebox are to be believed it may not even be around for much longer.
__________________
PEAYEL
PEAYEL's picture
I can only echo what others have said here. I have said before that I got rid of most of my audio kit and fully Sonos'ed the house.
I would like to add one more thing.. FAMILY. Whether you have loads or a few (relatives or children) they can all work.
The P5/P3 are also a "bit" of a technical achievement when you consider it, a set of amps, set of speakers and a network facility........ all in one box..... that sounds goodand fits in with the decor etc. Also the P5 is portable (has a handle). It was great out the back in the summer as well, (filled the garden with decent sound).
i also love discovering new music (see Aupeo), and listened to some Aussy radio last night. We all listen to loads more music and i mean loads more. My wife treats it like an Ipod. result.
SSSSoooooooooooooooo easy to do.
The down side was ripping my 2,500 + CD's to hard drive to FLAC format. It took months of a little bit every night etc, now its done, adding one or two every now and again is no pain.
brings a smile to my face every time. Just love the music.
__________________
Sonos ~ 2*P5, 2*P3, 2*ZP90, 2 * Sonos Controllers with Linn amplification and KEF & Mission speakers.
PEAYEL
PEAYEL's picture
I would like to add one more thing.. FAMILY. Whether you have loads or a few (relatives or children) they can all work it.
The P5/P3 are also a "bit" of a technical achievement when you consider it, a set of amps, set of speakers and a network facility........ all in one box..... that sounds good and fits in with the decor etc. Also the P5 is portable (has a handle). It was great out the back in the summer as well, (filled the garden with decent sound).
I also love discovering new music (see Aupeo), and listened to some Aussy radio last night. We all listen to loads more music and i mean loads more. My wife treats it like an Ipod............ result.
Brings a smile to my face every time. Just love the music.
__________________
dan_deelux
dan_deelux's picture
Another vote for sonos here! Just added a zp90 and i can safely say it's the best addition to my hifi system, set up was a doddle, it instantly recognised all the music on my nas drive and organised it on the app, and with spotify i can access tonnes of music; not to mention all the radio! Sound quality is great (imho) using an external DAC, we had a party the other night and it was great with all the guests lining up their favorite track on the playlist... It's not cheap but when you get it setup, you'll understand why! Cheers Dan
__________________
ipod classic 80gb - CA id50 dock - CA azur 650a - Harman/kardon hk770 - KEF iq50 - 500gb HDD - PS3 - CYP DAC - Sonos ZP90
acalex
acalex's picture
I also strongly encourage you to try the Squeezebox touch. Is cheaper than the Sonos, it is also very easy to setup, can stream from NAS, can access Spotify and internet radio and also accept hi res files up tp 24/96.
There are free apps for Iphone/Ipad/Android and honestly you do not need an external DAC. I tried a real time comparison with rDAC, also tried the SBT through the rDAC and couldn't hear the difference.
__________________
Digital Source: Logitech SBT + Netgear Ultra Nas 2
Analogue Source: TT Clearaudio Performance + EAR 834P Signature Deluxe phonostage
Ampli: Jadis DA50RC Signature
Speakers MA Silver RX6 --> SF Guarneri Memento on top of my list...
