Small speakers to fill a large room
6 replies [Last post]
Sari
Sari's picture
Current set up is: Nad C370 amp, Arcam Alpha 7SE cd and Quad 11L speakers. We moved to new property with living room size 7m x 4m with high ceilings, and the current system struggles to fill it. I would really like small speakers if at all possible. Would Acoustic Energy AE1 Classic be suitable? I will be doing this with a view of upgrading the rest of the system in the next couple of years. Budget approx. £800, am happy to buy second hand stuff also... pls help Smile.
Thaiman
Thaiman's picture
Re: Small speakers to fill a large room
YES....I had the MK2 pair few years ago and each upgrade since then they were on my short list. I am not familiar with the Nad C370 but give the AE1 plenty of power and they will rock your world.
__________________
TW Raven AC - Soundsmith SG-410 - MSB 202 - Gershman Acoustics Black Swan - Audioquest K9
jules153
jules153's picture
If Quad 11L (small speakers) don't fill your room with sound then you really need bigger speakers not different small speakers.
Remember that when 'small' speakers are on stands they take up the same space as floorstanders anyway.
I believe Triangle Altea are good one's in your price bracket and would allow further upgrades...
jules.
Ketan Bharadia
Ketan Bharadia's picture
Agree with Jules. The Triangles are a good buy. Don't ignore Monitor Audios RS6s (£600) or even better the Dal Ikon 6s (£899), though. I know the Dalis are over your budget, but I reckon they could be your best bet.
__________________
Technical Editor, What Hi-Fi? Sound and Vision
Thaiman
Thaiman's picture
You can't compare Quad 11L with AE1! If you look hard enough you can have a pair, ex demo, for under 500 notes. The Triangles Jules mention is also should be on top of your list as they are so fun to listening to.
__________________
Sari
Sari's picture
Many thanks all, got me to focus, back on track again. Small just won't do.
JoelSim
JoelSim's picture
I have the Dali Ikon 6s and they have a beautiful sound. But they are floorstanders, albeit quite slim.
__________________
Unison Research CDE, Leema Tucana 2, Kudos C2 and some cables.
