50 posts / 0 new
Last post
mini66's picture
Last seen: 3 years 1 month ago
Slim floor standing speakers needed?
I have looked at the PMC Twenty 23's as they are slim but I'm wanting something that's the next stage up (a bit better), recommendation's please?
plastic penguin's picture
Last seen: 5 hours 33 min ago
RE: Slim floor standing speakers needed?
What is your amp and max budget?
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
mini66's picture
Naim SuperUniti not sure on budget depends if it floats my boat Smile
Personally I love PMC Twenty 23s. Think you'll need to set some quality time aside to audition different brands/models. Try looking at PMC 24 or one of the Fact models. Also worth listening to Totem Hawks and Dynaudio (Contour S1.4 is a good place to start).
CnoEvil's picture
Last seen: 1 week 3 days ago
What are you trying to improve over the 23s?
It's possible that another brand will give you what you want, without spending more. Have you heard the Kef R500s. which are pretty slim, and would save you money. They are very good imo.
Remember, imo your amp, though good, has its limits as to how much it's worth spending on a speaker.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
Al ears's picture
Last seen: 1 week 1 day ago
You might try looking at the Vienna Acoustics range as they are pretty slim in general (6" drivers) but tend to be deep as well.
Second hand you could also look out for a pair of A.R.T. Audio Stiletto 6's which go very nicely with Naim kit.
Or, indeed, the very rare Acoustic Zen Adagio's :grin:
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
MUSICRAFT's picture
Last seen: 2 days 10 hours ago
Hi mini66
Monitor Audio's GX200's and the new and fairly slim Focal JM Lab Aria 926 speakers are also worth considering.
Fwiw, you might be interested to know that the new Aria range of speakers was partly developed using Naim electronics.
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi, AV Dealer
My system - Hegel HD30 > Hegel P30 > JL Audio CR-1 > ATC SCM100ASL Professional Monitors > 2 x JL Audio E-112
Coll's picture
Last seen: 15 hours 47 min ago
Rick see you are on line, been trying to get your advice.
Do yo think that the Arcam FMJ A19 will drive the new MA Silver 6s OK also do you think that those products would make a good system combined with an Audio lab 8200 CD player
mini66's picture
Don't get me wrong the PMC 23's are good speakers I wanted the 24's but my Amp is only 80w and I read somewhere the 24's recommend minimum of 100w ...is that right?
CnoEvil's picture
Here is a review by HFW, where they used a Supernait, which also has 80W. Check out the measured performance at the bottom of the page, where it says high power amps aren't necessary:
http://www.pmc-speakers.com/sites/default/files/attachments/HFW_Jun12%20PMC%20Twenty%2024_web.pdf
mini66's picture
If they state it needs 100w min, then why is that pdf file saying otherwise? *confused*
CnoEvil's picture
Where have you seen the "100W min" statement?
Their own brochure says this about the Twenty Series - "Ease of drive - They are efficient and therefore can be driven by the vast majority of good quality amplifiers, which allows partnering to the widest range of electronics possible."
mini66's picture
Cant remember sorry (it was from a company selling PMC speakers), I checked on PMC website and it doesn't state watts recommendation at all
PMCs are generally very easy to drive. I've driven DB1i and the older GB1s to very good levels with my old 40 watt Arcam.
Try and get some on home trial and see how they stack up.
mini66's picture
Thanks for all your help guys...I think the best thing is to phone PMC on Monday and get my answer from the horses mouth Smile
CnoEvil's picture
Personally, I think it's b*ll*x..
Pages
Log in to post comments
