Second system.
13 replies [Last post]
chebby
chebby's picture
Online
My second system (to go in a small spare room with an iMac) so far only consists of a lovely pair of JPW Sonatas* - with brand-new tweeters - sealed cabinet bookshelf speakers that I bought a few weeks ago. (Mint condition.)
I need an amp/mini system + AirPlay and DAC.
I am contemplating a Denon DM39DAB or Denon CEOL Piccolo N5 (the stripped down one without CD).  The problem with the Denon options is that the DM39DAB has FM but no AirPlay, and the CEOL N5 has AirPlay but no FM. (I like having FM.)
The CEOL is £249 (excl. speakers). the DM39DAB is £199 (excl. speakers).  Both options will cost more than I want to spend (£250 max) once I have filled in the 'missing element' in each case. (ATV or seperate FM provision.)
So, I think it's going to be the CEOL Piccolo and then wait for something like a mint, refurbished  Hacker Sovereign II or Roberts R900 radio for my 'retro' fix Smile
This is - to some extent - a stream of consciousness post (sorry for all the rambling) whilst I mull over options.
Feel free to join in with any ideas.  The only constants are budget (£250), speakers to be used (JPW Sonatas) and the iMac.
If your suggestion get's AirPlay and FM (in the same box) for £250 then i'd like to see it.
Ta.
*They sound excellent played on my normal system and have totally sold me on getting newer, more expensive sealed cabinet bookshelf loudspeakers eventually.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
John Duncan
John Duncan's picture
RE: Second system amp.
Does it need to be small?
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
chebby
chebby's picture
Online
Preferably but not essential.
__________________
John Duncan
Havne't quite found the right thing yet but Onkyo is my first port of call...
__________________
eggontoast
eggontoast's picture
Have you now changed your mind about a refurbished vintage set up such as the Sony you were looking at ?
__________________
Sonos > M-DAC, Beyerdynamic A1, FiiO E17/E9, HLLY DMK-IV, STAX Lambdas, Denon AH-D5000, Sennheiser HD-600, Beyerdynamic DT770, MCA customs - Magnum V4's, Sennheiser HD-265 linear, Sennheiser CX300-II.
pcookie
pcookie's picture
Why not buy another CR603?
Very cheap at the moment.
cookie
chebby
chebby's picture
Online
cookie
It certainly crossed my mind. But I don't need the CD player on it  (only need that occasionally on main system) and - despite being very cheap at present - it's still £80 over my budget.
Thanks though. Good idea.
__________________
chebby
chebby's picture
Online
Yes. I am too fussy to have anything but a mint one. (And I would also want to have it properly serviced before using it.) This could be very expensive. Add to which I would need an Apple TV and a cheap DAC for AirPlay and digital connectivity.
Too much money and extra boxes and wires.
Plus these old beasts can chuck out a fair bit of heat (even when idling) and take up a fair bit of room. (Not good for electricity bill either.)
They also tend to have millions of vent slots on top -and underneath - so become uber 'dust traps'
All-in-all, not so good in a small room.
__________________
John Duncan
Funcitonal requirements met, not so much on the size thing:
http://www.richersounds.com/product/av-receivers/pioneer/vsx527/pion-vsx...
__________________
paradiziac
paradiziac's picture
I've got a Creek 4330 hooked to my Sonatas in a 3rd system, sounds great for what it cost Wink
Alears
Alears's picture
Nice one John. A bit leftfield but all boxes ticked.
Maybe chebby could hide it in a cupboard.  Smile
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
BenLaw
BenLaw's picture
http://www.hughesdirect.co.uk/hi-fi/hifi-systems/pio-xhm71-k/product
£20 above budget but maybe you could find it without speakers somewhere.
__________________
HiFi   /   A/V   /   Bedroom
vikram
vikram's picture
RE: Second system.
The Denon DM39 is £190 at Peter Tyson or Richersounds and how about adding an Airport Express at £79, total £269?
Regards
Vikram
chebby
chebby's picture
Online
RE: Second system.
Thanks for all the ideas. I have read them and thought about them (and researched them on the web).
I am about 90 percent decided on the Denon CEOL Piccolo now.
I think I will just have to live without FM in the spare room. Everything else about the Piccolo is spot-on and I just keep coming back to it.
Cool and energy efficient (class D) the same power as my M-CR603, optical digital, ethernet and AirPlay and iThing compatible USB with charging.
Small, easy to clean. No top or side vents to suck in dust.
It is likely to have the same (or similar) sound to my M-CR603 (a good thing to me) given it's essentially made by the same company and has similar specs.
The JPWs are rated 87dB @ 8 ohms and 70 watts max (sealed cabinets, wall mounted). I will be listening from about 5 -6  feet in a small room (10ft x 12ft) at moderate volumes, so the Piccolo has enough 'grunt' for my purposes.
__________________
