20 posts / 0 new
Last post
ISAC69's picture
Last seen: 2 weeks 5 days ago
second hand Krell KAV-400xi ?
I found a second hand  Krell KAV-400xi  in a bargain price , Someone has an exprience with this amp ?
Hi Fi : Proac Studio 140MK2 / Mcintosh MC 152 / Mcintosh D 100 / Cambridge Audio CXC / YAMAHA BD -S677 / B&W P7 / Tellurium Q ,WireWorld,Audioquest & QED cables.
MattSPL's picture
Last seen: 1 year 7 months ago
RE: second hand Krell KAV-400xi ?
Nice amp. I had a Kav300i and a Kav300iL.
What speakers will you use with it?
ISAC69's picture
Hi
All my system components are mention in my signature bellow .  My speakers are Proac Studio 140MK2 .
What Do you mean "nice amp" -  isn't it good enough ?
lindsayt's picture
Last seen: 5 days 6 hours ago
Buy it! If it doesn't sound better than what you've already got, sell it for a modest profit.
nopiano's picture
Last seen: 5 days 7 hours ago
Are you certain it is working as intended and in good cosmetic condition?  How much is a bargain?
Krell CD and amp, Michell/Rega/Grado for LPs, Hitachi and Sony tuners, Nakamichi cassette, SBT streamer, Chromecast audio, Sonus faber Concerto Grand Piano spkrs. Qobuz > iPad > AudioPro Allroom Air One
bluedroog's picture
Last seen: 2 months 1 week ago
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;}
Personally I’d say tread with caution, just what is a bargain price? If it really is a bargain you could sell it on if you don’t like it and you’ve got a good price if you do. There is definitely demand for the 400 as it was an amp I tracked for a while before going another direction.
It has plenty of slam and in quite a modest sized package but just be aware that this amp can divide opinion and I found it wasn’t for me. I found it almost aggressively forward, shouty at times but some will have a different adjective to describe the same attributes as their personal taste with view them as a positive quality.
Unless you are familiar with the Krell sound I would try and listen to this amp before you commit and also carefully consider the synergy with the rest of your kit.
There is no doubting this is a quality amp and they seem to be very well built and can handle even the most demanding speakers.
BigH's picture
Last seen: 1 month 1 week ago
You may want to read this review:
http://www.stereophile.com/integratedamps/205krell/index.html
Listen to the music, not the hifi.
MattSPL's picture
Your speakers have a 3.2ohm minimum impedance. If you plan to play your music very loud regularly, this might be a problem for the Krell, because it is only rated to 4 ohms.
I had trouble with the Kav300iL driving some B&W N803's which dip to around 3.2ohms also. It was fine at normal listening levels, but for extended high volume listening, the amp got red hot and blew the speaker output fuses.
malthus80's picture
Last seen: 3 years 2 months ago
If you can get it for less than 750 and its in A1 condition id say go for it. Much as i love my naim pre powers, i always regretted not buying one when i had the chance.
malthus80's picture
If you can get it for less than 750 and its in A1 condition id say go for it. Much as i love my naim pre powers, i always regretted buying one when i had the chance.
malthus80's picture
malthus80's picture
malthus80's picture
ISAC69's picture
Hi
I can buy it for 1K from a dealer , I didnt check it phisicaly yet but I can do that . I am certenly worry that my speaker rated as 4 ohm min 3.2 will not be a good match , I read at Streophile website that the Krell can go very hot and the ventilation is a weak point on this amp .
I am realy confused ...
lindsayt's picture
Oh, I thought you said you could buy it at a bargain price. Not a slightly-under-the-going-rate price. I was thinking you'd seen one for sale for 500 quid or so.
the record spot's picture
Last seen: 1 year 10 months ago
Compared to what Krell normally goes for, £1000 probably constitutes a bargain.  That said, the OP should demo this before parting with the cash.  Really need to be sitting down in front of this thing for an hour or two, ideally with your own speakers if you can.
Pages
Log in to post comments
