Roksan or Yamaha to drive Atc ?
3 replies [Last post]
alchemist 1
alchemist 1's picture
   Considering Roksan caspian 2 or Yamaha as2000 to drive Atc scm20sl's.
   Opinions or experiences welcome.   Smile
tino
tino's picture
RE: Roksan or Yamaha to drive Atc ?
If you can get your hands on the March edition of HiFi Choice ... then there is a group test of the following amps - you should be able to get some hints from there and of course your own demo if possible.
  • - Roksan Caspian M2
  • - Yamaha AS-2000
  • - Arcam FMJA38
  • - Audio Analogue Puccini Settanta V2
  • - Creek Desitiny 2
  • - Prima Luna Prologue One
__________________
Squeezebox Touch | Wadia 151 | Aliante Moda PF
MUSICRAFT
MUSICRAFT's picture
Online
Hi alchemist 1
The Roksan and Yamaha are both capable driving SCM20ASL monitors. If possible try both amps to see which one you prefer the presentation of with SCM20ASL monitors.
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
drummerman
drummerman's picture
And whilst you there perhaps try one of the latest AV receivers, even much cheaper ones. They now measure as well as hifi amplifiers and have power as well as facilities to spare. You could save a lot of money.
In the same mould, Teacs A R-650 measured as well as Creeks Destiny 2 and has over 120 real Watts into 8, well over 200W into 4 ohms. Available for under £200 ...
regards
__________________
Pretty ... and pretty proud of it
