Roksan kandy K2
16 replies [Last post]
Tobber61
Tobber61's picture
I'm wondering how good the Roksan kandy K2 is,my system contains Rotel RCD 1072 ,RA-1062 and wharfedale Emerald 97 IV
but ,its very bright,harsh especially vioices makes very sharp ssss-sounds,
should the Roksan kandy combo (cd+amp)cure my problems or is the Roksan as bright as Rotel ,would like an overal smother sound
Read about the kandy combo ,but there are different opinions whether it's bright or not
sorry about the language,swedish
__________________
BigH
BigH's picture
RE: Roksan kandy K2
There was a post about Roksan Kandy 2 a day or 2 ago, from what some people say no the RK2 would not be for you. If you can wait see the Arcam amp in next months WHF reviews that maybe one, Arcam gen. sound fairly warm or NAD or Marantz.
dumbledore
dumbledore's picture
RE: Roksan kandy K2
Coild be just faulty speaker. I would check the tweeters they may have gone out of spec and dying. Look to see if both speaker exhibit same symptoms.
danrv
danrv's picture
RE: Roksan kandy K2
Hi
My experience with Rotel (RA-01) is that they're on the bright side of neutral. Before I bought the Kandy K2 combo, the sound was rather bright. Together with my CA 640C I had the annoying sssss..... on voices and metallic sounds such as cymbals and steel strung guitars would be a little piercing.
Took a fair amount of time and thought on how to sort it and didn't really know what component to change. Eventually took a bold move and bought the Roksan Kandy K2 amp and CD player. Sounds great now with my Dali Lektor 2s.
I think the Roksan K2 combo would improve your sound and smooth it out. Try and get a home demo if you can to hear how it sounds with your speakers.
__________________
Roksan Kandy K2 amp / Roksan Kandy K2 Cd player / Dali Lektor 2 / Chord Chrimson Plus / Chord Carnival Silverscreen / Atacama Nexus 6 / Target Hifi stand / Advanced Acoustics 3ft bass traps.
plastic penguin
plastic penguin's picture
RE: Roksan kandy K2
I would say the speakers aren't of the quality required for the Rotel or Roksan.
I've owned Wharfedale speakers since 1980 and found for every two models made that are fabulous, they do produce the occasional speaker that is specifically designed for disco levels and not hi-fi. I've not heard your  Wharfedales but would guess they would fall into the latter catagory.
FWIW I would take them along to a dealer and test them against B&W or Epos or Q Acoustics and see whether I'm right or talking total nonsense.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
BigH
BigH's picture
RE: Roksan kandy K2
I see the  Marantz KI Lite amp is now down to about £650, would that be a better choice than the Kandy?
richiesuk
richiesuk's picture
RE: Roksan kandy K2
it is actually 619
like it very much,and still very new.
__________________
Marantz CD6004--Chord cobra Plus IC--Marantz KI Pearl Lite Amp--Tellurium Q Black Speaker Cables--Monitor Audio BX5s....happy hours Smile
Tobber61
Tobber61's picture
RE: Roksan kandy K2
I´ve been thinking of Marantz as well,richiesuk ,I saw that you had the Cd6004 in your set up,did you compare it to the more expensive Ki pearl lite cdplayer
__________________
richiesuk
richiesuk's picture
RE: Roksan kandy K2
sorry, never heard the pearl lite cd player
__________________
richardw42
richardw42's picture
RE: Roksan kandy K2
If you're seriously thinking of changing to the Roksan pair, you're obviously prepared to spend quite a bit. So for that kind of money you could get some really serious speakers. I think you'd find this a better way to go.
For a £750 / so called 125Wppc amp the roksan disappointed.
__________________
TV room : Samsung 60" plasma-ATV3, Denon DBP2012UD-Yamaha RXV3067-AVI ADM9RSS,MA RSW12,/Sonos ZP90 via optical, Sky+ HD & Sky Connector, PS3
HiFi : Sonos ZP90 - AVI ADM40
Bedrooms : 2 x Sonos Play 3
Ipad for Sonos & Spotify
danrv
danrv's picture
RE: Roksan kandy K2
While I'm getting great results with the K2 combo and my Dali Lektor's, I do agree with richardw42 that maybe a really good pair of speakers would tame the brightness and bring out the best in the Rotels. I was considering that move for my CA Azur 640 and Rotel RA-01.
It's all about matching equipment and considering you have matching amp and CD player prehaps a pair of B&W 685's or CM1's would do.I've heard that Rotel and B&W have a good synergy.
__________________
Tobber61
Tobber61's picture
RE: Roksan kandy K2
Thanks for all the advices ,i'll be listening to à pair of B&W 684 tomorrow
I don't know  which way to go yet
regards
Tobbe
__________________
plastic penguin
Roksan kandy K2
Ahem... look at my post. yet again my posts get ignored.
__________________
danrv
danrv's picture
RE: Roksan kandy K2
Sorry PP. Should have mentioned you in my post.
__________________
plastic penguin
Roksan kandy K2
No problem.
Wharfedale used to produce ranges like a bottle factory, some ranges, like the Diamonds, were/are fabulous, while other ranges were designed with a specific brief.
A lot of this was kick-started by the 'E' range of the mid 70s. They were never originally designed for the domestic market. Rank Organisation, along with competitors, were designing high power speakers for cinemas. From that Wharfedale designed the E 90. They were big. Very BIG. You could practically land a Jumbo jet on them, and the slightly smaller E 70 and 50. Wharfedale pitched them, according to the Rank "suits", to compete with high-end Quad speakers of the day.
They had two major drawbacks: Firstly they had high dbs (my E20 are 97db) and the tag line, from memory, was: Want to entertain the neighbourhood? The 'E' series from Wharfedale is the choice.
The other sonic snag, according to some reviews at the time, was rubbish timing and imaging. This was mainly due to the shear amount of drivers they had, hence why I chose the entry-level version. They were THE speaker of their day: Wouldn't compete with decent speakers of today but they were a revelation at the time.
Sorry for boring the pants off you. poke, prod
__________________
ISAC69
ISAC69's picture
RE: Roksan kandy K2
I have the Roksan Kandy and ROTEL RCD-1520 CDP and they move my MISSION MX5 superbly , I demoed the Kandy with more expensive speakers
such as Proac Studio 140 and Sonus Faber Toy Tower act. and the results were always good. It is neutral and warm amp with a lots of raw power .
__________________
Hi Fi : ROKSAN KANDY K2 - PROAC STUDIO 140 MK2  - ROTEL RCD1520 -  interconnects : Tellurium Q Black - Chord Chorus2
AV : YAMAHA RXV767 - WHARFEDALE 9.CM [C] / 10.2 [SR] / INFINITY PRIMUS PS8 [SUB]
