5 posts / 0 new
Last post
admin's picture
Last seen: 5 days 10 hours ago
remote needed
Hi all, new to the forums but really enjoying reading them.  my  problam  is i have a Sony str db840 receiver but have lost the remote, i fear it fell off the arm of the sofa to the bin which i then transfered to the bin outside, doh, does anybody know were i might pick a replacement up from, second hand would be fine, would also be prepared to buy a non working amp just to get the remote.
VoodooDoctor's picture
Last seen: 2 months 1 week ago
Re: remote needed
I suppose that you have a few other choices. Get a compatible universal remote or phone Sony's spares supplier and order a genuine replacement. I bought a demo Sony TV a few years ago which had surround speakers but no cabling. Bought the cables over the phone from the spares people. Wasn't cheap, mind.
Anonymous's picture
Re: remote needed
Thanks for the reply voodoo, had thought about genuine replacement but as a last resort though as i will probably cost a bomb, hoping i might get a second hand one somewhere where the amps failed, doesn't really matter if it's not an excact match as all i want to do is alter the volume (down when wife walks in moaning about noise) then up again, do u know of any universals that will work sony amps
Re: remote needed
I should think all of them do. Could try emailing the manufacturer of the one that you think that you might buy to ensure it works first though.
Gwyndy's picture
Last seen: 3 years 11 months ago
Re: remote needed
You could try a second hand Phillips Pronto from eBay and the codes from remote central, have you any other Sony components as I believe that most of them are interoperable, my friends DVD remote also operates his TV and VCR.
Log in to post comments
