90 posts / 0 new
Last post
josh05's picture
Last seen: 7 months 4 days ago
Rega Elicit R - worthwhile upgrade?
Hey guys, I love the sound of my current setup but after reading a fair chunk of stevebrock's thread I'm curious. Would anyone know if this amp would be a worthwhile upgrade for me? is it a similar sound to the brio r but with more power for a better soundstage, imaging etc? I know the amp is worth twice the price of my speakers so that alone tells me maybe my speakers won't be able to show off enough of the amps potential to make it a worthwhile upgrade? With a bit of luck I should be able to demo it in a few months as I have a dealer in town here that stocks Rega, until then though it would be great if anyone could help out. Thanks
stevebrock's picture
Last seen: 4 days 15 hours ago
RE: Rega Elicit R - worthwhile upgrade?
Your speakers will be fine!
If anything expect the Elicit R to control them better!
I heard the Elicit R with Rega speakers costing half the price of the amp and it sounded fantastic!
I have already decided I am buying one after selling my bike which I dont use anymore!
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
plastic penguin's picture
Last seen: 1 day 22 hours ago
The best thing to do is to audition the Elicit with your RX6s. On something that seems, according to the review, to be more agile and open than the Brio-R I'd certainly recommend dem dem dem...
I wouldn't be concerned about the MAs quality, the caveat for me would there tonal balance.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
josh05's picture
awesome! now I can't wait even more to hear it! hopefully my dealer will have one in soon so I can bring one home for a listen. I have a feeling though they won't have one in for a while being a small shop in a small town. it will be interesting to see how good the DAC in the Saturn R is compared to the Rega DAC as well Smile
cant see it being much different
BigH's picture
Last seen: 1 month 1 week ago
Probably the same. Just looked it up and this is what Rega say about the Saturn R cdp: " The CD player section will benefit from the use of the dual Wolfson WM8742 DAC’s used in the digital to analogue conversion stage found in the hugely successful Rega DAC."
Listen to the music, not the hifi.
MUSICRAFT's picture
Last seen: 2 days 7 hours ago
Hi josh05
Where do you live please?
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi/AV Dealer
My system - Naim Core > Hegel HD30 > Hegel P30 > JL Audio CR-1 > ATC SCM100ASL Professional Monitors > 2 x JL Audio E-112
davidf's picture
Last seen: 36 min 25 sec ago
The Elicit-R is certainly a fair step up over the Brio-R, and will do a much better job with your speakers. I would audition though, as the Elicit is a little more forward sounding, which along with the RX6's relatively bright top end might be a little too much for some. I would also try the Arcam A38, which I feel would suit the RX6's much better, but try them both and see how you get on.
the little audio company, birmingham
audioquest / audio technica / amphion / bluesound / chord co / cornered audio / elipson / golden ear / innuos / jbl / kef / moon / ophidian / primare / revel / svs
I demoed the Elicit R with an RP6/Exact - it was beautiful - god knows how it sounds with the Aria phono stage!
An Elicit R, RP6 and Aria would be a kick ass set up - then choose an MC Cart of your choice!
MUSICRAFT's picture
Hi stevebrock
It is a kick ass set up Dirol  An Apheta cartridge is the icing on an exceedingly good cake Smile
All the best
Rick @ Musicraft
empacher's picture
Last seen: 8 months 2 weeks ago
David@FrankHarvey wrote:
....the Elicit is a little more forward sounding, which along with the RX6's relatively bright top end might be a little too much for some.
Interesting.  That may be a challenge for me.  I'm thinking that I need to focus my search on slightly warmer, laid back amps, but I guess only a demo will help me know for sure.  Looking forward to a bit of a comparison to the XS2.
Though Naim are quite forward too!
Your Totems are lovely, reckon the Elicit will grip them with some authority!
Apheta on an RP6 - now there is a thought!
Over on VinylEngine some US peeps have been demoing that combo with good results - a lot citing that maybe an RP6 with Apheta is nearly as good as an RP8
WHFI paired the Elicit-R with Totem Rainmakers. Should be fine IMO.
Use the mags as a guide, the only sure way is to demo, demo & demo!
I loved the Elicit R, but when the time comes I will have to listen to an XS2 as well £1600 is a lot of dollar!
Pages
Log in to post comments
