Recommend me some classical music
24 replies [Last post]
basshound
basshound's picture
I would like to dip my toe into the murky waters (to me ) of classical music. I really like the sound of cello,flute and obe so could anyone recommend some pieces featuring these instuments or even all three at once ?
        My knowledge of classical is very limited so if you could be specific about the recordings (links ? ) it would be very much apprieciated . Thanks
__________________
Dell laptop with Jriver MC16 playing FLAC->MF V-Link II->Moon300D Dac->ATC-CA2 Pre-> ATC P1 Power Amp -> ProAc Response D18 Floorstanders + Proac ER1 Sub ,Chord speaker cable and inters
JustJezz
JustJezz's picture
RE: Recommend me some classical music
I'm no expert but I did purcahse Alisa Weilerstein's cello concertos last week. The Elgar is really nice, not so sure about the Carter versions.
http://alisaweilerstein.com/home
Sospri
Sospri's picture
Try this one................
__________________
Logitech Touch > digital input > Naim Supernait >Chord Silverscreen >Spendor SA1s.
Naim Stageline > Inspired Rega P7 Rega Exact.
 Beyerdynamic DT 880 Pro
Covenanter
Covenanter's picture
This is very difficult because "classical" in the broad way that the term is generally used covers several genres of music from the 16th century (or earlier) to the present day.  If I were to recommend something on the cello, for example, do I go with a Bach Cello Suite or a Shostakovich Cello Concerto or something inbetween?
Can you help us thin the field a little?  Is there anything that you have heard that you like?  We could then recommend things of the same type.
Chris
PS Here are two links to cello pieces where you can hear samples.  I'm not saying they are the best versions but just ones I found where you can listen!
http://www.amazon.co.uk/Bach-Cello-Suites-1007-1008/dp/B000001GRZ/ref=sr_1_4?s=music&ie=UTF8&qid=1361899158&sr=1-4
http://www.amazon.co.uk/Shostakovich-Cello-Concertos-Nos-1-2/dp/B000EBD85E/ref=sr_1_1?s=music&ie=UTF8&qid=1361899263&sr=1-1
Covenanter
Saw her last year at Symphony Hall here in Birmingham..She is quite something!
Chris
gregvds
gregvds's picture
The last and third recording of the J.S. Bach Cello Suites by Pieter Wispelwey. Beautiful.
nopiano
nopiano's picture
All orchestral music will pretty much include some Cello, Oboe and Flute.  But there are concertos which feature these instruments as soloists accompanied by orchestra, as well as solo pieces like the Cello Suites already mentioned.
Lots of general recommendations here, and you can try before you buy somewhere like Spotify.
http://www.whathifi.com/forum/hi-fi/classical-music-cd-recommendations
I'd suggest a Mozart Flute concerto or two, and maybe something featuring James Galway, an outstanding flautist; or for a more contemporary player, Emmanual Pahud.
For oboe, try Heinz Holliger or Nicholas Daniel's recordings.  Naturally, there are countless alternatives.
http://nicholasdaniel.co.uk/recordings/
Happy Listening!
__________________
Hi-Fi: Krell KAV-300cd, Michell TecnoDec/RB250/Grado Prestige Black1, KAV-300i amp, Transparent balanced interconnects and bi-wire to Sonus faber Concerto grand piano speakers, Nakamichi ZX-7 cassette deck, Logitech Squeezebox Touch, Hitachi FT-5500 and Sony S570ES tuners, BCD Engineering stand, RA Powerlink, Chord powerchord, Grado SR60i cans.
AV: Sony Bravia KDL-32EX503 telly, BDP-S370 player with QED HDMI. Currently unused: Denon AVR-1705, DVD-1710, KEF KHT1005.2
DocG
DocG's picture
+1 for Wispelwey. You can find a Spotify link here.
matthewpiano
matthewpiano's picture
'Prelude a l'Apres midi d'un faune' by Debussy would be well worth a listen.  It is a short orchestral piece with an amazing range of tonal colours and some beautiful flute work.  Herbert Von Karajan's recording on Deutsche Grammophon (coupled with Debussy's wonderful 'La Mer') is my go-to for this music.
I'd also suggest the Dvorak Cello Concerto - a wonderful piece of music and beautifully played by Lynn Harrell in his recording on Decca or by Rostropovich on EMI.
__________________
Rega RP3/Elys 2, Roksan K2 CDS, Squeezebox Touch, Denon PMA720AE, Q Acoustics 2020i, Sennhesier HD595, Beyer-Dynamic DT770PRO, Chord Crimson/Chord Rumour 2
gregvds
gregvds's picture
I think this is the first recording he did. Second one is better. The third one that just was made now is a little bit special as a lower diapason was used (392Hz), making the cello sound a little bit more like a Viola da gambo.
If you like Cello, you should also try all the Viola da gambo repertoir, try some Jordi Savall sacd, the sound usually is simply breathtaking. But that's not classical music, but rather well baroque or pre-baroque. I can only but heartly recommend you Dispora Sefardi and Armenian Spirit (AliaVox).
And don't forget Paolo Pandolfo too, that recorded a beautiful Fantasias for the viols, Purcell, and the Drexel Manuscript, from Carl Friedrich Abel.
All these are really audiophile recordings and very beautiful music too (I firstly buy music and listen to music, now, if the recording and production can be as good as possible, that's a plus)
And just to finish with something totally different, the Four last Lieder of R. Strauss, by Lucia Popp... Amazing to tears.
FennerMachine
FennerMachine's picture
Any compilation by James Last.
Classical, pop and movie music jazzed up for a 'groovy' sounding orchestra!
__________________
CA 751BD , QUAD 44 pre amp, Quad 303, Quad 21L2
Denon AVR-3801, Samsung LE32R87BD 32" TV, Quad L2 Centre, 78DS
amcluesent
amcluesent's picture
Mozart, Clarinet Quintet, Horn Quintet, Oboe Quartet played by The Academy of Ancient Music Chamber Ensemble
Haydn, Six Trios Op.38 For Transverse Flute, Violon And Violoncello played by Barthold Kuijken
Telemann, Six Quartets for Flute, Oboe, Bassoon and Basso continuo played by European Baroque Soloists
Mozart, Flute Quartets, Oboe Quartet played by Les Adieux
Vivaldi, Oboe Sonatas played by Paul Goodwin
__________________
Stello CDT200, Squeezebox Transporter, Myryad MT100, Audio Analogue Maestro Settanta REV2.0, Sonus Faber Guarneri Homage  · Squeezebox Touch, Quad FM4\34\306, Sonus Faber Concertinos · Squeezebox Controller
atticus
atticus's picture
Anything with Jacqueline du Pré playing cello and Daniel Barenboim (who she married) conducting.
I also don't think you can go wrong with The Magic Flute by Mozart, which is a bit like pantomime for grown-ups.
basshound
basshound's picture
Phew ! Thanks everyone, that lot should keep me (and Amazon ) going for a while   beauty, eh
__________________
basshound
basshound's picture
No offence but might give that one a body swerve ! rolling on the floor laughing
__________________
Crossie
Crossie's picture
Sorry but not James Last - simply not classical.
__________________
Toshiba Netbook J River, Cyrus Pre XPdQX with PSX-R, 4 x Cyrus Mono X's, Wilmslow Phoenix with Bass Extenders.
