7 posts / 0 new
Last post
Overdose's picture
Last seen: 2 years 2 months ago
Quad 303 combination, renovation and speaker match.
As per the title, a friend of mine has a Quad 303 pre/power combination that needs an overhaul.
Could anyone recommend a good place to have this work carried out in addition to Quad themselves?
Also, I have no idea about the capabilities of these amps, so are there any particular speakers unsuitable to use with these?
Volumes will most likely not be disco levels and a standmount speaker would probably seem to be the favoured approach.
Budget, absolutely no help here, but I thought Spendor, PMC or Harbeth as the usual suspects for a starter and auditioning as many as possible was my advice, but that will perhaps be limited to whatever is stocked within a certain radius of Norwich.
Before anyone else gets it in, this is definitely for a friend (not me).   :grin:
Supreme's picture
Last seen: 2 years 10 months ago
RE: Quad 303 combination, renovation and speaker match.
Hi Overdose, I know that Fidelity Audio have had Quad amps in at there workshop. Here's a link to an upgrade they undertook, they may take on renovation work.
BigH's picture
Last seen: 2 months 1 week ago
There is a guy near Huntingdon that renovates Quad, I will try to find his details, he was either on here or some other forum. Will have to be tomorrow now.
Listen to the music, not the hifi.
Overdose's picture
Great stuff! Thanks guys.
bernasmeister's picture
Last seen: 3 years 8 months ago
I have "refreshed" my Quad 303 power amp with a NET Audio kit. They have a number of upgrades that can be done to the Quad 33/303 line. Check them out here: http://www.net-audio.co.uk/
I have the 303 connected to Monitor Audio RX6 speakers with a Beresford Caiman as pre-amp/source.
Hope this helps!
Overdose's picture
Hope this helps!
THank you very much for that. It does help.
How did you find the quality of the workmanship?
I actually bought the capacitors and PSU board kit and solder it myself. I would imagine that since NET Audio design their own kits, if you have the work done by them it will be as close as to "factory-fitted"...
Log in to post comments
