36 posts / 0 new
Last post
sherez's picture
Last seen: 3 years 3 months ago
Proac D18
Hello,
What is the most suitable amplifier to Proac D18?
I am listening to: vocal jazz funk some blues all the kinds of rock and pop hip hop rap rnb.
thanks.
plastic penguin's picture
Last seen: 1 hour 29 min ago
RE: Proac D18
I would suggest you listen to few different amps within your financial constraints.
One regular poster on here uses a Roksan Caspian with D18s, while WHFI have recommended Leema Tucana. Very different amps in different price brackets.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
davidf's picture
Last seen: 3 days 2 hours ago
RE: Proac D18
Naim Nait XS, Musical Fidelity M3i or M6i, Primare I22 or I32, or the Roksan Caspian.
the little audio company, birmingham
audioquest / audio technica / amphion / bluesound / chord co / cornered audio / elipson / golden ear / innuos / jbl / kef / moon / ophidian / primare / revel / svs
sherez's picture
RE: Proac D18
Did u mean Roksan Caspian M2?
sherez's picture
RE: Proac D18
Another question, i am listening to music from my computer and I want to know which DAC is the best for me until 600£.
thanks.
sherez's picture
RE: Proac D18
somebody please?
matt49's picture
Last seen: 1 month 2 weeks ago
RE: Proac D18
I have the Audiolab MDAC, which I find deeply revealing and transparent, though perhaps a tad bright. I don't have much experience with other outboard DACs.
Matt
BigH's picture
Last seen: 1 month 2 days ago
RE: Proac D18
I would get a Beresford Bushman only about £200 but good, new version coming out soon, you can try it out at home for 14 days I believe and return if not happy, as its direct from manufacturer it cuts out the middle men and is good value, WHF gave it 5 stars in their review.
Listen to the music, not the hifi.
recruit's picture
Last seen: 2 years 1 month ago
RE: Proac D18
Another vote for Naim with the ProAc's, I have the D28's with Naim and the sound is real foot tapping stuff, very good combination !
sherez's picture
RE: Proac D18
actually my direction is the M-Dac what do you think?
recruit's picture
RE: Proac D18
The Audiolab is a good DAC and preamp but you will still need amplification, personally I have not heard the MDAC with ProAc so cannot comment on how well the 2 will work together, but you need to demo the kit to be sure!
matt49's picture
RE: Proac D18
Have you looked at the round-up review of DACs in the July issue of WHF? You might find it helpful.
recruit wrote:
The Audiolab is a good DAC and preamp but you will still need amplification ...
This is correct, though if you have no analogue sources, you need only buy a power amp to sit between the MDAC and the Proacs.
Like Recruit, I haven't heard the MDAC + Proac combination, so can't say anything about synergy.
Matt
sherez's picture
RE: Proac D18
Why i need to buy preamp the m-dac is not enough?
matt49's picture
RE: Proac D18
No, I said you'd need to buy a power amp. You'd also need a preamp if you have analogue sources, e.g. a turntable, since the MDAC only has digital inputs.
Matt
sherez's picture
RE: Proac D18
And what do you think about the integration between MF M1 and M3I?
sherez's picture
RE: Proac D18
Did you hear this integration on Proac D18?
Pages
Log in to post comments
