12 posts / 0 new
Last post
alchemist 1's picture
Last seen: 1 day 17 hours ago
Pragmatism !
      Due to certain practical reasons I may well have to change my excellent KEF LS 50's for speakers with front covers :cry:
      I'm contemplating Kef's 100 speakers.
      Pros & cons between the two speakers ?
      How are the 100's for postioning ?
davidf's picture
Last seen: 4 days 2 hours ago
RE: Pragmatism !
As good as the R100's are, I dont think i could go from LS50's to R100's. but, if you have to.... Sad
the little audio company, birmingham
audioquest / audio technica / amphion / bluesound / chord co / cornered audio / elipson / golden ear / innuos / jbl / kef / moon / ophidian / primare / revel / svs
RobinKidderminster's picture
Last seen: 2 months 2 weeks ago
RE: Pragmatism !
I assume u r worried about small fingers? I think I would try a little DIY grille covers either round ones to cover the driver or a more traditional whole front cover?
What about car radio door speaker grilles from eBay?
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
RE: Pragmatism !
     Playing around with the idea of a quantum leap too B&W's pm1's , but would it be a quality leap for the extra investment.?  :?
davidf's picture
RE: Pragmatism !
They're certainly one of the best £2k speakers for high frequency performance - nice and solid, with no tizziness or grain - just open and detailed. Buying these would usually depend on music styles, but having owned LS50's ,I doubt you'd feel you're missing out. They'll need a little more care regarding placement though as they are fuller in the bass than the KEF's. Only a listen can answer it for you though.
ID.
ID.'s picture
Last seen: 5 days 5 hours ago
RE: Pragmatism !
Although once kids get a little older, that top-mounted tweeter is awfully tempting. I suppose that once it gets to that stage grills aren't going to be much of a deterrent either.
Singslinger's picture
Last seen: 1 year 4 months ago
RE: Pragmatism !
ProAc Tablette Anniversary perhaps, or the slightly bigger Response D1? The Tablettes sound best when placed on heavy stands at least 15 inches clear of rear and side walls.
ID.
ID.'s picture
RE: Pragmatism !
Can the LS50s be wall mounted out of reach? I believe that some people have also suggested wall mounting the kids to keep speakers safe, but this probably isn't advisable, or legal.
Captain Duff's picture
Last seen: 3 years 6 months ago
RE: Pragmatism !
If wall mounting isn't an option, and you tend to listen when the kids aren't there or are in bed then you may find your answer at the pet shop - thick bird cage covers in various sizes (and normally dark colours) that would be quick and easy to slip on and off. You could even glue a bit of bubble wrap to the inside of the side to go over the cones for extra accidental knock protection. Is it a bird, is it a plane, is it a LS50..!
RE: Pragmatism !
Easiest & cheapest? Teach your kids to respect property and some things they don't touch. I never found this a problem.
RE: Pragmatism !
                       Would B&W's fs 700 stands be  adequate ?
                       Being front firing ported bookshelf speakers I was hoping for easier placement.
davidf's picture
RE: Pragmatism !
They should work well - they are good, solid stands.
Log in to post comments
