Power Amp (using M-Dac as pre-amp) for Monitor Audio GX300 speakers
7 replies [Last post]
Julian_b
Julian_b's picture
Any thoughts or recommendations?
I am streaming via Squeezebox Touch to the M-Dac and currently using an old Cambridge Azur 640R Receiver to power the MA GX300 speakers. Though the Cambridge is doing a pretty good job I'm sure I can get a lot more out of the speakers with a power amp that's 'designed' for the job.
Thanks in advance....
__________________
AV: Oppo 83 Bluray, Yamaha RX V3067 AV, Monitor Audio Apex 5.1, Vortexbox Appliance 2TB, Boxee Box, Apple TV, Panasonic 46" Plasma.
HiFi: Squeezebox Touch, Audiolab M-Dac, Musical Fidelity A3.2cr Power Amplifier, Monitor Audio GX 300
Other: Cowon Z2, Fiio E17 DAC, Audio Engine A5 Speakers, Denon AH-D2000, Denon AH-D5000
VoodooDoctor
VoodooDoctor's picture
RE: Power Amp (using M-Dac as pre-amp) for Monitor Audio GX300
Budget?
__________________
MA PL200s, PL350C, PLW-15, PL100s
 Onkyo PR-SC5509 -> Leema Acoustics Pyxis, Hydra II (x2) & I
JRiver 18 Leema Acoustics Elements DAC Panasonic BDT-310 PS3 X360 Wii Virgin Tivo
 Samsung PS64D8000
bluedroog
bluedroog's picture
I use a Quad 909 and I’m very
I use a Quad 909 and I’m very pleased with it, you can normally pick them up for about £500-600, if you don’t mind spending a bit more to buy new then the new Elite range has replaced this model.
That said the M-DAC is reportedly better when connected via balanced connection, not that I’ve heard one but I’d be seriously tempted by something from Emotiva. They tend to divide option and many people are put off by the fan boys but they pack some serious power and I’ve read many favourable reviews.
Julian_b
Julian_b's picture
I think up to around 1000 quid - though less is always good if good enough.....
__________________
Julian_b
Julian_b's picture
RE: I use a Quad 909 and I’m very
Hi bluedroog - thanks for the input - I think taking advantage of the balanced xlr outputs of the M-Dac would make sense so I know that limits models but if spending on an upgrade then may as well improve the prospect of better sound. I've never heard Emotiva either but they seem great value and as you say have had some good reviews too....will have to see if anyone in Singapore stockks them for an audition. I also quite like the look of the Audiolab mono blocs though they are pricey....
__________________
artist
artist's picture
John Westlake, the designer of the M-DAC , is going to release his own Westlake brand mini power amps this year.
These are to be designed to accompany the MDAC and are to have balanced inputs.
See pinkfishmedia site for more info,
Regards
gordy.t
gordy.t's picture
Power amp for Monitor Audio GX300 speakers
 I use Avi s2ooo monoblocs to run my GX300's, these amps have excellent grip, soundstage and transparency and IMO a great pairing for the speakers, the build quaility on these amps is excellent and can be bought 2nd hand for around £500.
__________________
Julian_b
Julian_b's picture
RE: Power Amp (using M-Dac) for Monitor Audio GX300 speakers
Thanks Artist and Gordy.t for your thoughts. Will keep an eye on what John Westlake gets up to. When I purchased the M-Dac I thought it a bit strange that Audiolab only offered one balanced XLR Amp option currently with their mono blocs (and they have just updated their amps too). Maybe John decided he has to do what needs to be done to partner the M-dac best himself...... Has anyone tried/heard the Audilab mono bloc amps with the GX 300's?
__________________
