Please help me find a power amp
10 replies [Last post]
DeimosNZ
DeimosNZ's picture
I have a Music First Audio classic Mk II passive Preamp. I had initially planned to pair it with active speakers but after numerous trials with the likes of Quad, ADAM, Genelec and ATC speakers I have come to the conclusion active probably isn't for me. I like my music with a dollop of warmth which seems to come more readily from passve speakers.
So I have just been through months of speaker trials and I am down to a short list which includes the Harbeth SHL-5 and the Sonus Faber Cremona M Auditor. Both of which I have listened to several times. I like both the Harbeth and the SF but I slightly prefer the SF (it has a certain je ne sais quoi although the Harbeth also has it's charms). I am restricted to standmounts due to room size constraints.
I have used my Dussun V8i integrated for the comparisons but prefered both speakers with slightly warmer amps (Copland/Manley) which will be out of my budget for a while (budget probably around 2k GBP). Current source is a Caiyin CD player and a Squeezebox Touch into Xindak DAC (which will all be upgraded as funds permit).
Can anyone suggest some power amps (or monoblocks) I should trial? Balanced inputs would be a bonus.
I can get very good prices on the Usher R-1.5, MBL 8006A and TRIODE TRX-P6L Reference (but wouldn't be able to listen) if anyone has any experience with these amps.
My music preferences are pretty wide - so I am looking for something versatile. Solid state preferred (as I usually forget to turn things off when I go out/to bed etc).
__________________
DeimosNZ
DeimosNZ's picture
RE: Please help me find a power amp
PS: sorry for the grammar - can't seem to edit my post for some reason
__________________
Golly640
Golly640's picture
My Cyrus Mono Bloc X300's astounded me when I added them to my system. Perhaps not at the budget you want but the 200's also sounded good when I tested them.
__________________
Cyrus: DAC XP+, CDXT SE2, PSX-R's and Mono X 300's, Music Hall MMF 5.1 SE, Vienna Acoustic Beethoven Baby Grands.
Roksan Caspian M2 CD, Cyrus 8QX Dac amp, ProAc 150's MK II
daytona600
daytona600's picture
croft work very well with harbeths
ifor
ifor's picture
You could join the queue to have a home loan of a couple of the new Proprii from Graham Slee.
http://www.gspaudio.co.uk/hifi-audiophile.htm
__________________
Source 1) "Inspired" Manticore Mantra turntable c/w Rega RB 301 arm, Goldring 1042 MM Cartridge, Graham Slee Reflex M phono stage, Graham Slee CuSat 50 interconnect
Source 2) Cyrus CD8 SE CD player
Source 3) iTunes (ALAC), iMac, Devolo Homeplugs, Apple TV3, Toslink, Arcam rDAC
Source 4) Technics SL-7 linear tracking turntable.
Roksan Kandy L3 amp, Spendor A5 speakers.
Other rooms: more Airport Expresses and Homeplugs with Denon AV system and Denon Mini system.
Macspur
Macspur's picture
My choices would be, with your set up and requirements, in no particular order;
Croft, LFD or Sugden, saw one of these recently second hand for less than 2K.
Mac
__________________
Accuphase E350 amp, Electrocompaniet EMC1UP CDP, Siltech 25th Classic anniversary 330I  XLR Harbeth Super HL5 on Sound Anchor Quod ELS63 stands, Chord Odessey2 speaker cable.  Grado SR60 headphones.
DeimosNZ
DeimosNZ's picture
Thanks for giving me some options. Lavardin, Croft, Modwright and Sugden are all on my current list.
Speakers have about 40 hours on them now and the sound is still changing.
__________________
Macspur
Macspur's picture
Which speakers did you settle for in the end?
Mac
__________________
DeimosNZ
DeimosNZ's picture
Mac
I went for the Sonus Faber Cremona Auditor M. Just waiting for it to break in
__________________
CnoEvil
CnoEvil's picture
DeimosNZ wrote:
Mac
Good choice.
Your list of amps is also excellent, and I would add Musical Fidelity AMS 35P, if it fits in your budget (and you can find one ex-dem).
McIntosh is also a possibility.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
Macspur
Macspur's picture
DeimosNZ wrote:
Mac
Just as a matter of interest, why did you choose SF over the Harbeth's?
You will have a fine system once you've added one of the aforementioned power amps.
Mac
__________________
