8 posts / 0 new
Last post
Marvindodgers's picture
Last seen: 8 months 3 weeks ago
Pioneer A400 Amplifier Replacement
I have been very pleased with my Pioneer A400 amplifier for 23 years. However, there are definte signs of it "going home" over the last month or so. I'm torn between trying to getting an old friend repaired and the lure of new HiFi.
I would appreciate some advice on where to start looking to get the same kind of powerful, straight through sound that the A400 gives me. My speakers are Kef Q15 and I use multiple sources - CD, Sonos Connect, Yamaha E800 Dolby Surround processor and a Rega P3 record deck so a phono stage is a must. My listening is very diverse, from Metallica to Laura Nvula, via The Human League, The Beatles, Genesis, Blondie, The Pixies and everything else inbetween.
Any advice for a starting position would be much appreciated and I guess I'm talking in the £hundreds rather than £thousands budget wise.
Rega P3/Elys 2; Pioneer A-400; Marantz CD6005; Kef Q15; Sonos Connect.
BigH's picture
Last seen: 3 days 14 hours ago
RE: Pioneer A400 Amplifier Replacement
Well if you like Pioneer then the A50 is about £500 and has its fans.
Listen to the music, not the hifi.
omnibeard's picture
Onkyo TX8050. I have one and an A400, love them both, listen to a lot of similar music I suspect.
The Onkyo has bags of power, decent phono stage and on board DAC.
Cypher's picture
Last seen: 2 months 2 weeks ago
I would go for the Pioneer A-30 (I own one, awesome amp) or the Pioneer A-50. Both got some great reviews in german magazines.
matthewpiano's picture
Last seen: 4 weeks 20 hours ago
Having owned an A400, I'd suggest either the Denon PMA720AE or, if you can pay a bit more, the Rega Brio-R.  Both fabulous amps.  I haven't yet heard the Pioneer A-50 but it should be well worth a listen.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Pioneer A400  -  Wharfedale Diamond 220 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
MUSICRAFT's picture
Last seen: 1 week 1 day ago
Hi Marvindodgers
I would recommend getting the your A-400 repaired. Then look at improving your source and speakers as you've only scratched the performance potential of the A-400.
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi, AV & Multimedia dealer
Thanks for all the suggestions.  I'm currently exploring the repair route.
gasolin's picture
Last seen: 5 days 8 hours ago
What about this one http://www.richersounds.com/product/amplifiers-receivers/arcam/fmj-a18/arca-a18-blk normal price without any discount is in denmark where i live close to 2.5 more expensive
Hifi: Marantz PM8005,Marantz CD5005, Rega RP1 Queen Limited Edition, Q Acoustics 3020 on isoacoustics 130 stands, 2x4 meter Supra Classic 6 speaker cable, M2Tech Hiface 2 into TC Electronic BMC-2 and supra digital interconnect
Log in to post comments
