Pin back yer lug 'oles - Motorheadphones!
Oh yes, they've gone and done it now. As if pummeling you at the gigs wasn't enough, Lemmy and the boys are looking to rattle your cochleas with their own brand of headphones now; quick, run while you can (or "You Better Run" if you will)!
http://www.superfi.co.uk/m-476-motorheadphones.aspx
I had an e-mail about superfi's motorheadphone's this morning but i deleted it.
Well, I hung on to mine and bought a pair tonight!
Exploiting band names, what's next? Talkingheadsphones?
Seeing as they've been endorsed by the band, "exploiting" might be a tad keen there...!
Next could be EDITEDphones....just a thought.
- Login to post comments
Cue intro...
dugadugadugadugadugadugadugaduga. If you like to gamble.
Ha ha ,love it.
