PCD Speakers for NAIM olive series?
Hi all ,using NAIM 82,Supercap,250,CDI all olive series and recently serviced other source is a Stream Magic 6 streaming from a Synology NAS speakers are Heybrook Sextets which I would like to upgrade.
Looking for a floorstander if possible which will work close to a rear wall. music is mainly female vocal and I would like something that is good at low listening levels budget around 2k room size 4m*5m approx.
Regards
I very much doubt you'll find a pair of speakers that will work well as close to a wall as the Sextets do, as they were specifically designed to work right up against a wall.
Also, the 'olive' Naim stuff wasn't as forgiving as the current Naim stuff, so your choice of speakers that will work well with the olive style is limited. Add to that your requirement for a speaker to work against a wall, and your choices are pretty slim.
The obvious choice would be a used pair of Naim SBL's or SL2's, but these are quite different to whatyou're used to with the Sextets.
Thanks for the replies, I have the Sextets about 175mm from the wall are their any speakers that will work at this distance looking at the NEAT website they say some of there speakers will work close to room boundaries?
Any thoughts on these?
David I did try the Naim speakers prior to purchasing the Sextets but couldn't get on with the
Regards
Depends on the model. I don't know which ones they claim to work close to a wall, but in our demo room, but of those that we have (Motive, Iota, Elite and Petite SX), only the Iota is ideal for that situation. Even though the Elite is a downard firing design, they still need a bit of space.
Not uncommon, which I think is the reason behind their newer Ovator range.
Regards
With all that NAIM gear you've to try the Dynaudio Excite X32, or Focus 260.
LivingRoom
Rega RP3 / Goldring 1012gx # Synology DS213 > QED Performance USB > Rega DAC > QED Performance RCA > Rega Brio R > Supra Classic 2x4mm > Dynaudio Excite X12 and some times BK XLS200 MK II
BedRoom
SBT > G&BL teflon line RCA > NAD 3020i > Supra Classic 2x4mm > Monitor Audio RS1
