23 posts / 0 new
Last post
Covenanter's picture
Last seen: 1 week 3 days ago
Parallel lines
Marantz PM8005 / SA8005 / KEF R700s / AKG K702
Alantiggger's picture
Last seen: 6 days 21 hours ago
RE: Parallel lines
http://en.wikipedia.org/wiki/Parallel_Lines             ...    Smile
Alantiggger
chebby's picture
Last seen: 8 hours 39 min ago
RE: Parallel lines
_____________________
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
RE: Parallel lines
Oh dear!  The original post did have text but the s**t software of this forum lost it.  £1m listening room we are told.  £50 forum software though.
I said in my lost post how good the recording was and what I delight it was to listen to this old CD.  To skip a genre I then played Karajan playing Prokofiev's 5th Symphony, a recording which in its original CD version was nearly unlistenable to but now remastered is perhaps the definitive version of this great piece of music.
Chris
woodster's picture
Last seen: 8 months 3 weeks ago
RE: Parallel lines
Chris,
Just wondered wher you  got that piece from, Karajan playing Prokofiev's 5th Symphony, that is.
Hegel H160 Amp, Audiolab 8200cd, Auralic Mini streamer, Rega RP3 deck, Musical Fidelity M1LPS Phono stage, B&W CM8 speakers.
BigH's picture
Last seen: 2 days 6 hours ago
RE: Parallel lines
Sounds pretty pointless to me, maybe that is why their reviews differ from other uses reviews. I would have thought that a more normal living room would have been better as that is what most people will be using.
Listen to the music, not the hifi.
RE: Parallel lines
woodster wrote:
Chris,
Sorry only just seen this.  Amazon have it:
http://www.amazon.co.uk/Prokofiev-Symphonies-no-1-5/dp/B000001GHI/ref=sr_1_5?s=music&ie=UTF8&qid=1363012215&sr=1-5
As you will see from the reviews the1st with which it is coupled isn't so highly rated and indeed some people don't like the 5th but they are wrong lol.  The Penguin Guide says of this 5th "Karajan's 1969 recording of the Fifth is in a class of its own." and I think that is right.  It's an interested recording because when it first came out on CD, having previously been on vinyl, it nearly put a lot of people off CDs because it was simply awful.  It was so shrill that listening to it was like hearing someone scraping a fingernail down a blackboard.  Anyway now remastered it is wonderful.
Chris
camcroft's picture
Last seen: 5 days 16 hours ago
RE: Parallel lines
And theres me thinking  about Blondie :?
Marantz SR5023  Project Debut Carbon Turntable
The_Lhc's picture
Last seen: 1 month 4 weeks ago
RE: Parallel lines
BigH wrote:
£1m listening room we are told. Sounds pretty pointless to me, maybe that is why their reviews differ from other uses reviews. I would have thought that a more normal living room would have been better as that is what most people will be using.
Who's living room? Yours? mine? None of our rooms will sound the same, nobody has a "standard" living room, so how are you supposed to pick one that's representative? You can't, so you create a room that adds nothing (or as little as possible) to sound of the equipment and then you review the equipment, not the room. You haven't really thought it through have you?
This is why reviews are only a guide, you have to do your own listening, ideally in your own room, to make a choice.
BigH's picture
RE: Parallel lines
Covenanter wrote:
woodster wrote:
Chris,
Chris
I think it is 1968 recording.
RE: Parallel lines
BigH wrote:
Covenanter wrote:
woodster wrote:
Chris,
Chris
1969 in my CD booklet.  Smile
Chris
BigH's picture
RE: Parallel lines
Well it is '68 in the Gramophone and Amazon review or are you referring to the release date? "Karajan's 1968 Prokofiev Fifth is a great performance."
woodster's picture
RE: Parallel lines
Covenanter wrote:
woodster wrote:
Chris,
Chris
Many thanks. Apologise for my shockingly bad English Grammar in my last post.
RE: Parallel lines
You might be right!  The Penguin Guide has it as 1969 but that might be when it was released, which would make sense for a late 1968 recording.  Whichever it is it is a great performance.
Chris
BigH's picture
RE: Parallel lines
"I said in my lost post how good the recording was and what I delight it was to listen to this old CD"
Thanks for that, one that escaped my collection, may well add it. And I agree about the forum part also.
BigH's picture
RE: Parallel lines
The_Lhc wrote:
Who's living room? Yours? mine? None of our rooms will sound the same, nobody has a "standard" living room, so how are you supposed to pick one that's representative? You can't, so you create a room that adds nothing (or as little as possible) to sound of the equipment and then you review the equipment, not the room. You haven't really thought it through have you? This is why reviews are only a guide, you have to do your own listening, ideally in your own room, to make a choice.
That is a fair point BUT I still think it is misleading and when they say things like positioning is not fussy they mean in their specially treated room that presumably has bass traps and sound panels so there are few reflections. They may not get bass boom when speakers are 1 foot away from a wall but does not follow you won't, so maybe they should be guarded with some of there comments. Not everyone can home demo gear before buying.
Pages
Log in to post comments
