One box system options?
18 replies [Last post]
womble72
womble72's picture
I've got Linn Classik (the old one), Myryad Mi and Arcam Solo on my list of 2nd hand options, what else should I consider and what, in your opinion is the one to beat? I have a 4x3 room with solid brick walls and exposed floorboards, a mix of oak furniture and two sofas and I will be looking to partner my 'one box' system with a pair of speakers (undecided on floor or stand mount) that will be good enough for bass heavy dance and rock tracks.
I'm leaning towards the Myryad Mi but unsure what speakers to partner it with.
Help puzzled
dariushifi
dariushifi's picture
RE: One box system options?
What about Naim Unity, Cyrus? You have to include these into your demo list  for sure. I have the same size room as yours and UnityQute does a very good job. Very pleased. Although, at first, I was concerned about 30 watts amp, but once I demoed it in the shop at 50 % volume I realised that I never gona listen that loud anyway. Indeed back in my room I never passed 45 mark.
__________________
SONY Bravia 32 EX723, Denon DBP2012UD, Naim UnitiQute, B&W685, Nac A5, Chord Active HDMI 1.4, Chord Crimson Plus
amcluesent
amcluesent's picture
Aura Note premier would be an option
__________________
Stello CDT200, Squeezebox Transporter, Myryad MT100, Audio Analogue Maestro Settanta REV2.0, Sonus Faber Guarneri Homage  · Squeezebox Touch, Quad FM4\34\306, Sonus Faber Concertinos · Squeezebox Controller
Ketan Bharadia
Ketan Bharadia's picture
Out of those three I liked the way the Myryad sounded best. It's nice and detailed but remains listenable too. If you're sticking to 2nd hand it's worth trying to find an Audio Analogue Enigma. It's not as common as the others but is a good sounding unit. As for speakers, Q Acoustics 2020is will work well, and if you have a bit more budget have a listen to Tannoy's DC6s.
__________________
Technical Editor, What Hi-Fi? Sound and Vision
therecruiter
therecruiter's picture
Personally if you after an 'all in one' then the Arcam Solo / Solo Mini is good BUT they can't beat the usability and sound that the Marantz CR603 can offer
This with good speakers blows almost all of the competition out of the water in my opinion...
It has recently replaced a Cyrus 8VS2 and Rega Apollo CD player I had in the spare room with some Monitor Audio RX2's and it's fantastic! I wanted rid of the stand the Cyrus/Rega stuff was on and this sits nicely on the bookshelf and recives everything via AirPlay (iTunes) and via the wifi connection using an ethernet bridge (Netgear universal one).
Bought mine 2nd hand for £250 as well so personally I think you'd struggle to beat it at that price
__________________
Living room: iTunes to ATV 2 (via AirPlay) to Cyrus 8 DAC with KEF LS50 speakers - Tellurium Q Blue cables
Spare room: Marantz CR603, AirPlay, Monitor Audio RX2's - Chord Odyssey 2 cables
ID.
ID.'s picture
Never gave it an extensive audition, but for some reason my local store always had it set up with some B&W 805S. Proabably wasn't doing the speakers justice, but it sounded damn fine. The styling may not be to everybody's taste.
__________________
Observe the signature in its natural habitat.
Singslinger
Singslinger's picture
Well strictly speaking the one to beat is the Burmester 111 Music Centre, but at £26,800 I doubt many people would be looking at it as a serious option. The Naim SuperUniti would probably rank high on any list of affordable one-box players to beat but if you can, try one of the streamers from German firm T&A. Their E series gear comes with very powerful built-in amplification or you could consider the MP 1260R, which doesn't have an amp.
drummerman
drummerman's picture
For probably not much more (less?) you could probably get one of AVI's integrated, cd player and perhaps a tuner. Not an all in one but much more powerful, still small and perhaps more suitable for your musical preferences? An alternative thats all.
regards
__________________
Pretty ... and pretty proud of it
Big Chris
Big Chris's picture
__________________
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
womble72
womble72's picture
I would buy this just for the name Laughing out loud
Thanks for all the suggestions, I'm not too fussed about streaming, radio on occaision and it would mainly be used for playing CDs. I have the clearance from SWMBO for a new hifi, It can be played as loud as I would like but it must not be a tower of boxes :-/
I have considered just having active speakers and buying a cd transport but I've never owned actives before and unsure of the benefits.
I like the look of the Myryad and have seen these go for about £5-600 2nd hand which would leave me about the same for a pair of speakers.
Helmut80
Helmut80's picture
woooh! I thought the devialet premier was pricey.  What are the odds than Cno can top this?
OneBoxSystem
OneBoxSystem's picture
Now we're talking......
Plus one on the SuperUniti.
CnoEvil
CnoEvil's picture
silenced shifty puzzled
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
dariushifi
+1
SuperUniti all the way.
__________________
Singslinger
Hi Womble72, looks to me you're after a network player that has built-in amplification, plays CDs and streams from a NAS or computer. I'm not sure if many such boxes are available, other than the one you mentioned or the Naim Uniti/UnitiLite so your choices are quite limited. Of the lot listed, I'd say the Uniti is the one to beat but the new Uniti Lite is definitely a contender ( though it may be over-budget). Good luck!
Native_bon
Native_bon's picture
Correct me if am wrong but the superuniti does not have a cdp or built in  hard drive. Not sure if that passes as an all in one?. You still need a source to get it to sing.
__________________
No rules. If it sounds good to you it sounds Right!!.Transpor:t . Oppo BDP-105EU Blue ray player.DAC: Rega dac & Audio lab M-Dac. AMP; MARANTZ SR7007. SPEAKER'S; SONUS FABER CREMONA'S. (FLOOR STANDING) SYSTEM STAND:QUADRASPIRE. INTERCONNECT;CHORD CHAMELEON SLIVER PLUS. DIGITAL CABLE:Clearer Audio silver Optimus. SPEAKER CABLES: RUSS ANDREWS CRYSTAL-24... Mains conditioner: Isol 8.
Computer: Yototech: 600T case: graphice GTX690 Graphics card. 32gb RAM. Processor: I7 3960X. Solid state drive. 500gb. Sata drive 2TB. blue ray drive. studio monitors: Yamaha SH80M Active speakers. Mixer: Presonus studiolive 16.0.2. Audio connection Firewire via presonus. Screen: Asus 27inch VG278H
