Olive 04HD analogue or digital output?
27 replies [Last post]
Ian64od
Ian64od's picture
Hi
I use my Olive in conjunction with a Cyrus 8xpd qx. If you have this set up do you find you get better results using the Olive's analogue output in to the Cyrus or the digital output in to the Cyrus?
cheers
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
SEE Revolver TT/CA 540/Ortofon 2M Red.
The_Lhc
The_Lhc's picture
RE: Olive 04HD analogue or digital output?
Which do you prefer? You own the kit, let us know, yours is the only opinion that's important.
__________________
No signature worth mentioning...
Ian64od
Ian64od's picture
It's Ian,
I have a definite favourite way round of connecting them. I have no idea which device has the better DAC and so was hoping someone might give some technical reason why one way should work better than another. Does the Olive or Cyrus do a better job converting the digital signal to analogue?
I prefer the sound made when I send the Olive analogue signal in to the Cyrus.
Ian.
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
omnibeard
omnibeard's picture
Then Bob is definitely your uncle, no?
Ah, you want to know why Bob is your uncle...
Ian64od
Ian64od's picture
I suppose I do want someone to tell me that this DAC is better than that DAC. If I don't get the answer I'm expecting will it make me change my mind about what sounds best.... I doubt it.
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
omnibeard
omnibeard's picture
Then Bob is certainly your uncle.
Ian64od
Ian64od's picture
But which Bob as there are two of them in question.
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
omnibeard
omnibeard's picture
You know, Uncle Bob - your favourite uncle!
The_Lhc
The_Lhc's picture
The one that gives you the sound you like best! That's all that matters, you even said yourself if someone told you the Cyrus DAC was better you wouldn't change and if you did you'd be a fool anyway.
__________________
Ian64od
Ian64od's picture
Ok you win with the uncle Robert thing
but to satisfy the techie geek that lies within me, does anyone know which DAC is likely to be better spec'd the Cyrus qx or the Olive 04HD?
it would open up a train of thought about the link between component quality and the sound produced that's all.
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
drummerman
drummerman's picture
Online
One probably costs a fiver. The other one, pushing it,  could be as much as £6.00.
Now we have a dilemma ...
... I just wish they'd make them with nicely coloured little legs. It really would make things easier.
regards
__________________
Pretty ... and pretty proud of it
Ian64od
Ian64od's picture
I thought I was asking an acceptable question but between drummer and omnibeard I feel what was the point of asking in the first place.
there has to be a technical reason for the difference I can detect and if someone has a sensible contribution to make I'd love to hear it.
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
cse
cse's picture
[quote=Ian64od]
 Agree, they both come across as very arrogant.
__________________
Ian64od
Ian64od's picture
Thanks cse, I note your response on my other thread too.
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
drummerman
Online
You two should lighten up a little and perhaps more importantly ... not take things personal ...
There are bound to be likely minute differences between the Olive and the Cyrus. They probably dont use the same DAC and they almost certainly dont have the same output stage which ... most likely, will make the bigger although still small difference. - Both are probably done fairly well so should, in an ideal world produce equally acceptable results. I would however assume that the Olive, being their entry level product (?) has somewhat less elaborate engineering compared to their higher priced ones. Perhaps they just engineered some degrading of sound into it as, as far as I know, it is not too difficult to make a perfectly decent product with minimum engineering fuss based on the DAC boards freely available to most hifi manufacturer, high end or not.
Peace and love ... well love anyway
regards
__________________
cse
cse's picture
regards
That's a much better response. Well-done, you can be nice if you make the effort.
__________________
