Old amplifier for Mission 760i speaker
6 replies [Last post]
romeo
romeo's picture
help, I`m sinking
have a pair of old middle-class speakers Mission 760i
Enclosure Type: 2 way bass reflexDrivers: 1 x 130mm bass/midrange | 1 x 19mm dome tweeterFrequency response: 70Hz to 20kHz ±2.5dBNominal Impedance: 6 OhmsSensitivity: 89dBRecommended amplifier: 25 to 75 watts
[img]http://www.hifidatabase.com/static/gallery/9/small-3099-760i.jpg[/img]
and need to feed it. plz help me to figure out what  stereo amplifier is best for it.
think about:
LUXMAN lv-111
Luxman LV-100
Harman/kardon Hk6100
Harman/kardon PM-640vxi
ONKYO A-8620
ONKYO A-8015
Marantz PM461
Telefunken TA350
DocG
DocG's picture
RE: Old amplifier for Mission 760i speaker
Hi Romeo,
I happen to have the 760SEs (which should be quite close to yours). Still using them - some 20 years by now. I recently hooked them up with a Unison Simply Italy, a 2 x 12 W single ended tube amp, and the result was excellent, my point being: these are really fine speakers, with a good sensitivity and a rather benign impedance curve (you summed up the specs in your post). I think every decent amp can make them shine.
The bad news is that I'm not familiar with any of the amps you name; I use a 2 x 45 W Yamaha amp (just as old as the speakers are), which sounds fine, but does not - as I recently realised - bring up the best in them. I'm sure others on the forum can be of more help suggesting a good match. But the bottom line will be: audition for yourself, if possible in your own listening room.
All the best!
romeo
romeo's picture
thanks for your answer!  beauty, eh Unison Research Simply Italy is might be a very good and quality product, that can extract 100% of potential from mission 760i, but its to expensive for me now  Crying i try to find some budget amp.
maybe you have some minds about fisher ca 7000/7700?
very nice amp with good price (less than 200 dollars)
now I feed it  from mini stereo JVC ex-D11 with built-in DAC and 2x20Watt 4 Ohm amp. the sound is not bad, but I think it might be better  excellent!
DocG
DocG's picture
Not saying you should get a Simply Italy (that would be overkill++), I wanted to point out they're not a difficult load for any amp.
As I said, I have little knowledge of the amps you quote; I only know that Luxman have some very good equipment, and also some really mediocre stuff (like my old DVD-player), so if you consider it: try before you buy.
I hope some of the more skilled forumites will pop in to help you out.
DocG
DocG's picture
Double post. ohhh sure
romeo
romeo's picture
I can get the luxman lv-100 for about 40 pounds, may be its the best buy for its price?
CnoEvil
CnoEvil's picture
Luxman, as a brand, would be my pick.
Can't comment on those models..........and how it (LV-100) sounds, will depend on what condition it's in (may need a service).
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
