14 posts / 0 new
Last post
jcarruthers's picture
Last seen: 2 years 10 months ago
New speaker cable
My thrifty ways a few years ago have come back to haunt me — the "just enough length" speaker cable is now too short after purchasing some stands and moving bits around.
Suggestions on some new cable? I don't find much wrong with the Chord stuff but I've never auditioned cables before.
You can probably put me in the cable pessimist camp but if I were to ask for anything it would be for a bit more "attack"
stevebrock's picture
Last seen: 5 days 3 hours ago
RE: New speaker cable
Odyssey 2
Upgraded from the Silverscreen - got more tight bass & soundstage now - yes it's pricey but mine was and eBay used bargain
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
abacus's picture
Last seen: 1 day 2 hours ago
Go to your dealer and ask to demo some speaker cable at various prices, do the test blindfolded, (Or walk out of the room when they are changed over so that you cannot see which is which) then when you find out (As everybody that tests blind does) that there is no difference between them, buy the cheapest. (Alternatively pop down B & Q or similar and pick up some nice thick cable from there)
Hope this helps
Bill
BigH's picture
Last seen: 1 day 18 hours ago
Get some Van Damme OFC, 4mm is about £5 a metre. If that is too much then VD Studio Blue is good and about £3 a metre.
Listen to the music, not the hifi.
skutters's picture
Last seen: 3 years 9 months ago
I have just bought some thick multi strand OFC cable from Maplins to use with my newly bought Harbeth P3esr speakers and it works a treat, absolutely no difference from the £30 a metre cable they were using at the dealers when i auditioned the speakers.
                                    Regards Kev.
RobinKidderminster's picture
Last seen: 1 month 2 weeks ago
Agreed skutters that decent ofc is fine tho it is a common 'discussion' here, some able to differentiate different cables. However, I would never trust that a dealer demo and a home installation can ever be identical when trying to identify the indisputable smaller changes that cables may cause. Please accept this as an opinion and not critisism since the only important thing is your satisfaction with your system.
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
Triggy's picture
Last seen: 1 hour 54 min ago
RE: New speaker cable RE: New speaker cable
Hmm., different speaker cables do sound different!
I've heard the difference and made my choice accordingly!
You pays your money and takes your chance!
If you enjoy what you hear, that's great!
Sorted!
Thanks for all your replies.
To be honest I don't mind paying for decent speaker cable — it usually looks good and is nicely finished — but I am a skeptic for anything that costs £££
BigH > have you got a link to the Van Damme 4mm stuff?
Looking at the WHF award winner — it's even cheaper than stated as the price is for bi-wire. You can get the 14/2 stuff for £3.45 a metre.
nopiano's picture
Last seen: 5 days 13 hours ago
Does this help?
http://www.audiovisualonline.co.uk/product/1938/van-damme-tour-grade-black-speaker-cable-2-x-4mm
Krell CD and amp, Michell/Rega/Grado for LPs, Hitachi and Sony tuners, Nakamichi cassette, SBT streamer, Chromecast audio, Sonus faber Concerto Grand Piano spkrs. Qobuz > iPad > AudioPro Allroom Air One
Thanks — that's great.
davidf's picture
Last seen: 36 min 28 sec ago
                                    Regards Kev.
Did you order it from Maplins and then take it to the dealer to try against their cable?
owner at the little audio company
high quality audio solutions for real world music lovers
BigH's picture
Sorted!
Yes but some of those "hifi" cables are seriously overpriced.
I have read 4 articles and posts by speakers manufacturers who tend to agree about expensive cables.
BigH's picture
Sorry just seen your post found this one:
http://www.ebay.co.uk/itm/VAN-DAMME-HIFI-SERIES-STUDIO-GRADE-SPEAKER-CABLE-4-0mm-/200606890719?pt=UK_Musical_Cables_Leads_Connectors&hash=item2eb51a3adf
To be honest the 2.5mm is fine unless you have long runs. If you want a lot you could buy from Farnells but will have to buy 50m min but works out a lot cheaper, you could even sell on the left over for a profit.
Log in to post comments
