need help with bx5 and pm6004 set up
Mon, Dec 3 2012, 8:35PM
this is my 1st time setting up and duno much about speakers
i am jus wondering what is the best bi wire to go with the speakers and is the bass difference between bx5 and bx6 significant in a 3x3m room? also which phono to 3.5mm should i get?
thank you
With that set-up I wouldnt bother bi0wiring to be honest; just not worth it.
However if you can; use a small piece of the same speaker cable to replace the speaker terminal jumper bars on the speakers themselves.
Also for a 3 x 3 room; the BX5's are MORE than enough! I'd say be careful as they could prove to be fairly bass heavy in a room that size. They kick out plenty of low end
Living room: iTunes to ATV 2 (via AirPlay) to Cyrus 8 DAC with KEF LS50 speakers - Tellurium Q Blue cables
Spare room: Marantz CR603, AirPlay, Monitor Audio RX2's - Chord Odyssey 2 cables
