Naim or Cyrus system for Kef speakers
17 replies [Last post]
Dommer
Dommer's picture
hi guys, I've been using the Logitech transporter with Linn AV 5125 power amp and Kef Q10 bookshelfs for streaming all of my music from a NAS. And the audiolabs 8200CD for the ocasional CD and iMac (via dac) playback.
The Transporter has been sold and I've been looking at a more compact all-in-one streamer that would give a similar sound.
My two options are the Naim UnitiQute or the Cyrus Stramline. Does anyone know which would be more suited for the Kef Q10's.
The Linn is borrowed from a friend, and will need to go back eventually, hence why I'm looking at a streamer with built in Amp.
thanks
__________________
Naim UnitiQute, QED Genesis Silver spiral cables, KEF R100.
Audiolab 8200CD, QED reference silver spiral interconnects, ProJect head box Amp, Grado SR225
CnoEvil
CnoEvil's picture
Online
RE: Naim or Cyrus system for Kef speakers
It may come down to the presentation that you prefer.
If you like the Linn sound, you should also look at the Sneaky or the Sekrit DSI.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
Dommer
Dommer's picture
Thanks CnoEvil, I do like the Linn sound and would love to go for the Sneaky, unfortunately Linn streamers are quite a bit out of my price range. I need to decide on an ex-demo streamline or UnitiQute as those fit my budget.
__________________
CnoEvil
CnoEvil's picture
Online
Not sure what your total budget is, but here are new prices and I'm sure all can be bought ex-dem if patient:
Cyrus Streamline...£995
Linn Sneaky DS.....£850
http://www.superfi.co.uk/p-3935-linn-sneaky-ds-networked-media-player.aspx
Naim UnitiQute.....£1425
Linn Sekrit DSI....£1500 http://www.newcastlehifi.co.uk/products/ebz_product_pages/linn_sekrit_ds...
__________________
Dommer
Dommer's picture
My budget is up to £1000.
I didn't realise that the sneaky DS has come down in price. Just wondering if it would sound better then the streamline. SQ is most important to me but the stramline seems to be quite a lot more versatile with input and outputs as well as a better control interface. Ah decisions decisions.
__________________
CnoEvil
CnoEvil's picture
Online
The Linn has a competent amp, provided the speakers are reasonably efficient and you don't use it for a disco.  The Streamline is good value, as it used to cost more, and has a more powerful amp....it may come down to presentation.
__________________
Dommer
Dommer's picture
I'm starting to think that I should just use my Audiolab's DAC with the iMac for now and look at upgrading the Kef Q10's to something like the Spendor S3's or the new KEF R100's. If I stay with the Q10's and go with a Sneaky DS or Streamline, I might not notice much of an improvement over the transporter I used for two years.
__________________
CnoEvil
CnoEvil's picture
Online
You are certainly looking at very nice kit......with your current thinking, what amp would you be using?
I suspect that coming from your current speakers, you will prefer the Kef R series to the Spendors, which might be a touch smooth and undynamic.
Do report in with how you get on.
Cno
__________________
Dommer
Dommer's picture
Thanks for your great suggestions Cno. If I upgrade to the KEF R100s, and use my audiolab 8200CD as the main player/dac then I might ad a used audiolab 8000A integrated which I can buy from a friend for a very good price.
I might visit a local Sevenoaks to listen to the KEF R100s this weekend. Otherwise I will keep the q10s for now and go for a Cyrus Streamline.
will let you know either way.
__________________
Dommer
Dommer's picture
I auditioned a pair of Monitor Audio 50s as well as the Spendor SA1s and S3s with the Cyrus Streamline yesterday, the dealer did not have the KEF R100s. Both the MAs and S3s sounded good to me, but the SA1s were exceptionally good! Now I am thinking of just going for a pair of the Spendor SA1s which I could get for about £900.
But then also found a great deal on an ex demo Naim UnitiQute, unfortunately I can't afford both the UQ and the SA1s, so it's going to be a hard decision.
__________________
kungula
kungula's picture
if your budget allows it try the KEF R 300, they are a highlight in the R series.
__________________
1)  living room: Naim SuperUniti, Neat Elite SX, Sonos bridge 2) office:  Dynaudio 110 A, Sonos ZP 90, NuForce HDP Dac, Ripnas Z 1000 3) kitchen: Sonos S 5
CnoEvil
CnoEvil's picture
Online
The SA1s have been my favorite small speaker since they came out, but now are imo challanged by the Kef R series, so as has been said above, you should try them before committing (and save some money if you prefer them).
The success of the SA1s will be determined by the size of your room, which if too big for them, will mean you will be better off with something like the R300.
__________________
kungula
kungula's picture
the R 300 can be used in a small or medium sized room. The R 100 I would personally only use in a small room for best performance.
__________________
Dommer
Dommer's picture
Thanks guys, my lounge is quite small at only 3x4m. So the KEF R100s should be good enough. Perhaps best to go for the UnitiQute now and check out the R100s when I save up a bit.
__________________
Dommer
Dommer's picture
Well I finally decided and went for an ex-demo Naim UnitiQute. Should be delivered this friday. So will spend the weekend comparing it to the Audiolab/Linn seperates.  In time I will upgrade the speakers to something better. Maybe a pair of KEF R100, or even PMC's or Neats, if budget allows.
__________________
CnoEvil
CnoEvil's picture
Online
That all sounds good, and (imo) you are looking at the right speakers as well.
__________________
