NAD C326BEE does it need to burn/run in?
31 replies [Last post]
MeanandGreen
MeanandGreen's picture
Hi Folks,
I've just unboxed my new NAD C326BEE, it is replacing my oldC350 which has stopped working.
Doed this amp need to run in? Just it sounds like the upper midrange and lower treble sound very forward compared to my old amp. The reviews for the C360BEE say it is bass heavy, but compared to my C350 it sounds a bit lacking to be honest. Maybe my ageing C350 was sounding a bit  soft and wooly with age and I'm just used to that presentation now. I just hope this new amp isn't going to be so fatiguing.
I haven't even had an hours use out of the new amp yet, but I'm sick of hearing it I've just turned it off.
My old amp sounded very smooth and easy to listen to, yet still very dynamic and had enough detail to satisfy me. The new one has given me a headache in half an hour and a just found myself skipping through a playlist rather than wanting to sit and listen, it seems so "in yer face" if you know what I mean?
I have a Sony CDP-XB930 CD player, iPod touch with Arcam iR dock and B&W DM 601 S3 speakers. QED qunex silver spiral and qunex2 interconnects and silver anniversary biwire speaker cable.
I appreciate any advice thanks! I'm hoping after a few hours the sound will tame down a bit and become more natural.
__________________
NAD C326BEE Amplifier, Sony CDP-XB930 CD Player, Pioneer PDR-509 CD Recorder, Arcam irDock with iPod Touch, B&W DM 601 S3 speakers, Jamo 20"Stands, Revolver Rack, QED cabling throughout, Sennheiser HD 518 & HD 565 Ovation Headphones, Beyerdynamic DTX-101iE ear buds.
plastic penguin
plastic penguin's picture
It does need a period to 'settle' IMO, although others will probably have different theories. You need to factor in the 326 will sound slightly different to the older model. It'll take a few days before you notice any difference.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
Native_bon
Native_bon's picture
RE: NAD C326BEE does it need to burn/run in?
Ur not the first, or would u be the last to say this. Countless times on this forum, anyone moving from old amps to the very lastest ones say the very same thing. Bright & forward. welcome to the new world of thin sounding amps.. Only use reviews as a guide. Make sure u always audition at home.
__________________
No rules. If it sounds good to you it sounds Right!!.Transpor:t . Oppo BDP-105EU Blue ray player.DAC: Rega dac & Audio lab M-Dac. AMP; MARANTZ SR7007. SPEAKER'S; SONUS FABER CREMONA'S. (FLOOR STANDING) SYSTEM STAND:QUADRASPIRE. INTERCONNECT;CHORD CHAMELEON SLIVER PLUS. DIGITAL CABLE:Clearer Audio silver Optimus. SPEAKER CABLES: RUSS ANDREWS CRYSTAL-24... Mains conditioner: Isol 8.
Computer: Yototech: 600T case: graphice GTX690 Graphics card. 32gb RAM. Processor: I7 3960X. Solid state drive. 500gb. Sata drive 2TB. blue ray drive. studio monitors: Yamaha SH80M Active speakers. Mixer: Presonus studiolive 16.0.2. Audio connection Firewire via presonus. Screen: Asus 27inch VG278H
toyota man
toyota man's picture
I would suggest you run your amp at low volume for a couple of days that will I am sure be all thats required good luck
__________________
altruistic.lemon
altruistic.lemon's picture
10 to 15 minutes is all that's required. Your ears may adjust to the sound - if they don't, take it back and try another amp.
MeanandGreen
Thanks for your replys folks Smile
I'm hoping that once I give it a chance it will settle down or I'll get used to it. I used to love a forward sound but these days I seem to be favouring warm rich tones.  Which going by the reviews from the press and regular people on the net this is exactly what this amp should be.
I haven't been able to give it anymore use as yet, I have other people I the house who don't always want to hear my music. I will plug my sennheiser's in later and have a couple of hours with it and get  it warmed up.
There are no NAD dearlers close to me so auditioning wasn't really an option, I just thought it would be a safe bet. My old amp was quite possibly sounding a touch soft after 13 years maybe.
Thanks again, I will report back after I have givin it some proper use. Smile
__________________
rymidd
rymidd's picture
yes mine sounded alot better after 30 hours.   Before burn in it may sound a bit thin.
rymidd
rymidd's picture
MeanandGreen
It's certainly a bit thin compared to my c320, that was a rich smooth powerhouse. This c326BEE is very full on in comparison. It sounds nothing like the warm bassy side of neutral amp that I've read about. Just had it on for a couple of hours there and I dunno if I'm just listening for faults but the sound is grating on me.
It's not all bad, vocals and guitars are incredibly clear, but the overall sonic picture sounds a bit sharp and strident. The lowest bass notes don't seem to have the power and definition that I'm used to.
Over the next couple of days if it doesn't improve it's going back unfortunately. Maybe a second hand c350 is what I'll have to look out for.
__________________
MajorFubar
MajorFubar's picture
I don't want to sound negative but I suspect it won't change very much.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
rymidd
rymidd's picture
on my nad c326 i used the tone controls to up the bass , i know this amp has a reputation for being to bass heavy. i never found it to heavy on bass. but the bass is very fast and tight . when i first got mine i was not sure about it because it sounded a bit hollow out of the box. but with 20 to 30 hours there was more warmth  to the sound. but it might be a system matching problem i had the quad 11L speakers which may be warmer sounding to the b&w 601 s3 which i also used to have.
the record spot
the record spot's picture
I think the only "new" amp I've had of late was the Onkyo TX-8050 and that has a very neutral presentation, so if you're using bright electronics with it, then it'll sound bright, or woolly or whatever.  Depends on the source music too.  In your case, I'd leave the amp on for a day while you're around, not listen to it, and then give it another whirl.  I should make it clear I don't necessarily buy in to the whole "burn-in" thing, a couple of hours tops for me, the rest if maybe you getting used to the new sound of your amp.
My main amp stock comes from Ebay or Gumtree by and large and it's reaped dividends overt the years (Sansui AU-217 / 717, Sony TA-F630ESD, Harman Kardon HK6850).  Quality has been way above what I'd look to spend, but the usual caveats apply with used and/or vintage gear.
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
miggyboys
miggyboys's picture
Hi MeanandGreen
I've had a NAD C350 for 10 years, which I'd also describe as powerful, solid sounding, very warm and detailed (which I'm in the midst of upgrading if I can find something I like!). If you end up taking the NAD back, you could try Rotel, they've often been similar to NAD in terms of characteristics i.e. warm, musical, dynamic - have a look at the Rotel RA-10, £350. WhatHiFi gave it their 'Awards 2012 Product of the Year - Stereo amplifiers'.
__________________
HiFi: Logitech Squeezebox Touch, Marantz CD6000OSE, Audiolab M-DAC, NAD C350, Denon TU-260L II, Tannoy Revolution R2, Vortexbox, QED & IXOS interconnects, QED Silver anniversary bi-wire speaker cable.
AV: Sharp LC-46LE831E, Denon AVR-2310, Sony BDP-S363, SkyHD, Mordaunt Short Genie 5.1, various QED & IXOS interconnects, QED Silver anniversary speaker cable.
Miggyboys
plastic penguin
miggyboys wrote:
Hi MeanandGreen
From all the Rotels I've heard they ain't warm. Still own RCD 975 and is a fabulous sounding CDP, but isn't as smotth as the Arcam, which has similar sonic traits to Nad and Creek.
__________________
zenobia
zenobia's picture
I heard similar sharp and strident quality when I had one in my system briefly, ran it in for about 150 hours with no real change so I returned it.  I've had a lot of unlistenable amps that I wanted to turn down or simply off and "break in" didn't fix that problem with any of them.  I suspect if you like the older nad sound you'll likely need to search for an SS amp that most people think overly warm these days.
Been through a bunch of amps myself with a pair of vienna acoustics bach (old model) speakers: harmon kardon 3490, peachtree, marantz pm, nad c326, rega brio-r, yba, pioneer av.  The Harmon Kardon and peachtree are the only two that didn't constantly assault the ears with steely violins, horns with too much bite, and a generally hard, artificial and unnatural treble -- both these amps had a full, warm sound with smooth mids and highs that allowed you to listen happily on and on.
If you want something clearer, faster, and more detailed you might try the pioneer a-30, a-40, a-50 integrateds, as do I find my pioneer av receiver to be very detailed and lively in the treble (none of the murkiness of the hk or peachtree) yet without much of the usual fatigue I associate with that sort of presentation.
I suspect Arcam a18 / a28 might also be a good fit for smoothness & warmth.
Edit: It might also be that your speakers are bright and harsh and need the warmth of a smooth amp to sound natural (I half suspect this may be my problem, too, or all these 'neutral' amps really sound shi%)
rymidd
rymidd's picture
also  using silver coated cables wont help with brightness.
