17 posts / 0 new
Last post
admin's picture
Last seen: 1 day 20 hours ago
my new and first system??
Anonymous's picture
RE: my new and first system??
This is the third time ive had to write this post this sorry my question wasnt on the first actuall post. please reply to this reply????
I recently just purchased a system off ebay its an eltax 5.1 including 2x liberty 5+,2xsilverstone rear's,1xcentre.
I also purchased a sony amp reciever str-de 495, i then wired them all up with cable i also purchased off ebay. and connected the reciever to my 43inch samsung plasma via optical audio cable.
Then for the big moment, i turn everything on and its really quiet and when it gets halfway up through the volume it just cuts out and the reciever says PROTECT.
I also know its not the reciever because the guys in the store tested before i brought it and it sounded great through 2x standard speakers with normal black and red cable
Could this be the speaker cable?? what kind do i need?? why is it cutting out?? thanks and any replies to this would be much appreichated thanks, michael
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
Check all wiring and no shorts?
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
Juzzie Wuzzie's picture
Last seen: 2 years 6 months ago
As above, check wiring.
Anonymous's picture
yeah the wiring is fine all new cable perfectly cut and pushed all the way into the plugs.
its quite thin wire though id say 30 strands
Anonymous's picture
sorry i just counted the strands and its only 13 strands per + and - so 26 in both parts of cable
is this a good amount? can crap cable make it trip out?
Big Chris's picture
Last seen: 2 years 9 months ago
13 strands sounds very, very thin. If the cables are long enough, then the excessive resistance could well cause the amp to trip out.
Anonymous's picture
there is no excess cable there cut to fit perfect.
could 13 strand cable be the cause of the trip out?
theexcitableboy's picture
Last seen: 2 years 2 months ago
Thin speaker cable you find on eBay is prone to issues. Take a look on the likes of Amazon for something a little more substantial. I'm not talking The Chord Company, but something you can trust. Van Damme is a fine cable, and the 2x2.5mm version is going for £2.60/metre at the moment, and there are cheaper alternatives too.
Even if the cables are not to blame for the fault, you'd still benefit from an inexpensive cable upgrade in terms of sound quality.
Overdose's picture
Last seen: 2 years 1 month ago
It is unlikely that the cables themselves are the issue. It is more likely to be the connectivity or a component short.
Try one speaker connected at a time to check all speakers first.
Anonymous's picture
thanks for replies ill try them both
Sizzers's picture
I don't wish to appear ignorant, but wouldn't the protection circuitry kick in automatically if there was a short regardless of volume level?
Edit: According to the Sony user manual the "Protect" circuit kicks in when there is a short. Just seems odd to my mind that it seems volume dependent in this case but I'm always willing to learn.
Anonymous's picture
what exactly is a short and how do i look for it? sorry if this is a stupid question im a newbie
Anonymous's picture
Overdose's picture
A short is basically a 'shortcut' that allows electricity flow such as to avoid a load (resistance). As in many things, electricity will always take the path of least resistance.
What you need to do is find the source of the problem before you can deal with it. It sounds like your amplifier is having a hard time of things and checking out the speakers in this manner will help isolate the fault. If all speakers are ok and the wiring and connectivity are sound, then there is a problem within your amplifier.
toyota man's picture
Last seen: 3 months 3 days ago
A short is when the + speakerwire wire touchs the - speaker wire  I would disconnect all speakers and the anp an reconnect one speaker at a time making sure that the wires do not touch each otherand test each time you add a speaker good luck:) Smile
Musical Fidelity M6500i, Musical Fidelity M6 CDP, Musical Fidelity Encore Connect, ATC SCM 40s, Cord Chameleon plus XLRs, Tellurium Q Black speaker cables.
Pages
Log in to post comments
