Music Orientated Home Cinema System
Current system: Arcam Alpha 7R stereo amplifier, Yamaha DSP-E800 home cinema processor/amplifier, Mordaunt Short MS817 stereo speakers, MS824D dipole rear speakers, MS304 centre speaker, MS308 subwoofer, Pioneer DV575A DVD/SACD/CD player, Limit DJ2000SQ turntable, JVC AV28T25 28” CRT television. Plus various other items such as a set top box, a (wired) network mp3 player, as well as old media players that I barely use like Mini Disc, Video and Cassette.
Room: 4m x 4m (very approximately) with hard wood floor (& rug to suppress vertical flutter echo), near full height curtains can be drawn on both sides.
Questions: I’m getting fed up with the plethora of different separates taking up half my living room and the miles of cables connecting them! I’d like to rationalise without compromising my music listening. I’ll be starting by throwing out at least some of the old media players mentioned above.
Amplifiers: Would I be able to replace the two amps with a single home cinema amp that improves (or at least maintains) the quality of my stereo audio listening experience? If so, how much would I need to spend? If that’s impossible, inadvisable or simply too expensive, I’ll probably upgrade to a better stereo amp instead and keep the DSP-E800 as the surround processor/amp.
CD/DVD player: I’m looking to upgrade the player. My collection currently includes CD’s, SACD’s, Audio DVD’s and Video DVD’s so the new player would need to be able to handle all of those. It would also be nice if it could play some of the new formats such as Blu-Ray. I’d like to consider using a games console as the player, particularly if it had an Ethernet port with network media server software compatibility (because then it would play all my discs and my networked mp3’s, as well as games). However I’m concerned about the potential for a loss in audio quality with a games console compared with my present player. Also, as an alternative to upgrading my present player should I consider a separate DAC?
Turntable: My present model is a hangover from the days when I was into mixing with two (or more!) turntables, which I no longer am. I’d therefore like to replace mine with one more suitable for the living room environment and which I hope will sound much better. Budget: up to £500 including cartridge (and phono stage if I replace my current amp with one that doesn’t include a preamp on the phono input). I guess it would be the Pro-ject RPM5?
Speakers: My centre speaker leaves a little to be desired. Can you recommend any that would be a good match for the MS800 series? (Possibly difficult!)
Rack: I currently don’t have a decent rack. Could you please recommend one that preferably has at least 4 tiers, of which one will accommodate a cinema amp if possible? Budget: up to £400.
Mains power: I’m interested in a mains filter and I noticed you recommend the Isotek Gemini 6-way on page 87 of the September issue. However it doesn’t appear in the listings at the back – has it been reviewed?
Many thanks for your reply. I'll certainly consider purchasing the rack and turntable you suggest. I think I'll also look for a DAC now and wait to upgrade the DVD player until the HD market developes a bit more. It sounds as though you think the MS304 is well suited to my setup - to my ears it doesn't seem a particularly good match with the MS800 series but then I suppose not many thaings would be! Amp budget £700 - what would you suggest?
- Login to post comments
Personally, I can't see many problem in your setup. You certainly will need a rack and something like "sound stlye ST100" would be good enough. Turntables? for the amp and speakers you have, £500 would be overkill. So my humble suggestion would be along the line of PROJECT DEBUT III. DVD player with standalone DAC is the way to go (I found DVD player are great when use as transport) I would try Toshiba HD-XE1 and Beresford 24 bit conversion DAC (search ebay!) Mains power: I wouldn't borther! spend money on a discs would be more sensible choice. Oh and yes, you should get a hifi amp and keep Yammie processor, what is your amp budget? regards
TW Raven AC - Soundsmith SG-410 - MSB 202 - Gershman Acoustics Black Swan - Audioquest K9
