Monitor BN2 Speakers
9 replies [Last post]
meh1
meh1's picture
Hi, ive never brought a good set of speakers and im looking to update some wharfedale 7diamond speakers..having read the reviews im interested in buying monitors bn2 speakers,just wanted some advice to whether they are actually any good..also looking for some where i can buy a pair for under 200pounds? Also will these two speakers be enough by themselves or should i look to get a sub as well?cheers
Andrew Everard
Andrew Everard's picture
Re: Monitor BN2 Speakers
 Monitor Audio BR2s?
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
meh1
meh1's picture
yer that would be the ones...sorry! any advice that you could give would be greatly appreciated. thanks
Andrew Everard
 Yes, they'd be a very good upgrade. As for pricing, that's down to you and Google, I think...
__________________
Cypher
Cypher's picture
The Monitor Audio BR2 are amazing speakers for the money.
Buy them as soon as you can, that's the only advice I can give you.
Lupan
Lupan's picture
If I am using the ATC SCM11 now, would it be silly to get the BR2 to see how they sound like as they seem to be getting pretty nice reviews all over?
Andrew Everard
 Yup, daft as a brush. The ATCs are in an entirely different league.
__________________
meh1
meh1's picture
Just been doing a little research on prices for the br2's, however im a little confused as to whether i would have to buy them seperately or would such  a product usually be sold as a pair? They are retailing around 200 pounds but i dont know if thats just for one speaker? also been looking at speaker cable...will it make much of a difference to the performance and sound quality? thanks
Andrew Everard
UK prices for stereo speakers are given for a pair, unless stated otherwise (for example in the case of speakers designed to add to surround systems for 6.1- or 7.1-channel working, or subwoofers).
Yes speaker cable will make a difference, but I wouldn't spend a fortune on cabling for the BR2s: the likes of QED Silver Anniversary or The Chord Company's Carnival Silver Plus would be fine.
__________________
meh1
meh1's picture
 cheers for the help andy..much appreciated
