Meridian DSP 3200 + AC 200 - Third time Active Speaker Disappointment
46 replies [Last post]
WishTree
WishTree's picture
Either I am going this all wrong way or I am not meant for actives!
With the disappointment of AVI ADM9T (not the latest version) and the Dynaudio Xeo5, I have decided to give another chance for Active speakers with Meridian DSP 3200 + AC 200.
I went with my wife for audition and had already filled her head with the technical prowess of DSP 3200 - about how active speakers make it easier on power amplifier, how a 400Hz cross over is so important (I read some where on HDD forums by Ashley about the crossing over and in my head I remember it that it is important not to cross the drivers in human voice range to avoid unplesant dips - I might be wrong), how the speakers can work near walls etc etc
I used my Macbook Air to connect via USB to AC 200 and played all the songs that we heard many times at home. The speakers were free in the room on a wide table (looked audiophile enough - heavy and no vibration) along with AC 200. It is about 3-4 feet into the room and we were sitting some 4-5 feet away.
Out of the box, Meridian sounded excellent bass for their size. My wife has to ask few times if there is a sub conected somewhere..
That's it.
Apart from the convenience of a small size, there is nothing more to write if I have to write positive. Ok, the finish and build are excellent.
What we did not like are the overpowering mid bass, soundstage was somehow felt wrong and voices went very much behind the instruments. At home with out any tweaking we hear the singers clearly and balance of the instruments to voices is normal / correct and with the system Meridian has put in it was quite behind. There is no musicality or seperation of instruments. If some one had told me that it is a Mini / Micro system sound, I would have just believed it.
We were told that the system was not run-in enough and we were also told that since we never heard correct bass, we feel the speed of the bass as higher volume of the bass  doh!
I would give the benefit of doubt about system not run-in but still..
I almost thought that I found the perfect system for me to go with my relocation but I did not expect such a big disappointment.
For now, I will stop chasing actives (though it is a pity that with Classe CP-800 a beautiful & simple system can be set up but alas for now I give up)
Also, this unforked path of passives speakers (atleast for now), put me on to explore different kind of speakers. Immediately on radar / soon to be auditioned are Anthony Gallo Strada and Vivid Audio V1.5
I am aware that there is a huge price & size difference but I want to see what would my current maximum budget will get me to.
in the mean time, KEF R300 are brilliant !!
__________________
My System  |
HiFi: Oppo BDP-105 | Jolida JD-1501BRC | AG Strada | B&W 608 | Toshiba-46TL933G
HT: Sony BDP-S790 | Marantz SR6006 | Wharfedale DX-1 7.1 | Sony-55EX725
oldric_naubhoff
oldric_naubhoff's picture
RE: re:
I had a chance to hear the same system last year at Dublin's hi-fi affair. suffice to say we - myself, my GF and friend - spent maybe about 1 minute in Meridian room. the sound was shrill and very fuzzy to my ears.
that really depends on quality of xover itself. well design xover will not exhibit any freq dip. but there's a good reason for shifting xover point as low as possible and letting one driver, if it's capable, to do most of the job - phase coherence. one driver will always be in phase with itself.
and if you really want to let one driver to do the whole of human voice 400Hz xover point is not enough. 200Hz looks more like it.
That's it.
that's actually the artefact of small drivers doing job of large drivers. high levels of intermodulation distortion make small speakers sound more bassy than they should and also you loose on resolution in midbass.
I also found this system to sound like there was no separation in instruments. just a wall of noise.
LOL! that's a good one. like I just said, what you heard was harmonic distortion, and maybe bass reinforcement from the table plane (if the speakers weren't put on the edge of the table) so how can this be any correct?
if you ever want to hear how bass truly sounds like you have to listen to large bass drivers. it may, ironically, initially sound bass light. but only until when you realise that where there should be bass there's plenty of it. and then you start to appreciate increased midbass resolution, because there's virtually no harmonic distortion in the bass region.
if I may point you in the direction of large planar speakers... shifty you seem like a guy willing to experiment. and this experiment may come through as revelation for you.
__________________
Giro, InTheGroove, Digit, ClassicOne, MG12
WishTree
WishTree's picture
RE: re:
Thanks oldric! It looks like I am not the only one to trash this Meridian system.
Yes, I am willing to experiment in a slightly convoluted way 'cos I also wish that HiFi fits in home rather than home needs to fit for HiFi which seems more likely Sad
The point is - I love the concept of Planar speakers and I have never heard them. The little I read, told me they are fussy about positioning and they are generally huge to look at which makes them out of the equation, for me.
But I have a feeling as time progresses, I might get the right place where there might be a place in home just for HiFi and these physical challenges can be overcomed.
Right now, I am looking forward to some possibly 'out of the box' speakers like Anthony Gallo Strada and the reviews say that then sound a lot like ESL.. I will keep us posted!
__________________
My System  |
TheHomeCinemaCentre
TheHomeCinemaCentre's picture
What you are hearing with the Meridian's is there sound. I wouldnt let that experience put you off active speakers in the same way that if you didnt like PMC or B&W it shouldn't put you off passive designs.
The Vivids are a completely different sound to the Meridian's but I suspect you will like them coming from the R300's. We put our K1's against the KEF 207's and they are not chalk and cheese.
__________________
Nick
The Home Cinema Centre
andyjm
andyjm's picture
RE: time Active Speaker Disappointment
Active loudspeakers are widely used in professional circles with firms such as Genelec the common choice for studio montiors.
The retail market has been slow to respond, but at the low end there are some standout products (Squeezebox Boom, Sonos Play3, Play5) which show what you can do with modern DSP and multi-amped setups, and at the higher end Meridian and ADM.
I certainly believe that active / dsp speakers are the way of the future.
Have you considered using room equalisation? The LF problems you describe are more likely to be room resonance problems than the speaker themselves.
__________________
ellisdj
ellisdj's picture
RE: Meridian DSP 3200 +sappointment
I have Meridian kit - not dsp speakers and I dont think the Meridian sound is exactly how it is being described here.
The mid range is maybe slightly recessed in its presentation and there is always a lot of bass
I have read the post and I can understand the dissapointment when the hopes are so high when the price tag is equally so, but I have realised that my Meridian kit has made me notice the flaws in my setup / room placement of speakers etc and thats what it sounds like a little bit in this instance. I would bet putting them in a better listening environment acoustically would yield much better results.  I also thought the op would have prefered the M6 as they more like his current speakers - larger etc.
He is also very lucky - I would love to hear some Vivid Audio speakers to hear what they are all about - lucky you !!
__________________
Meridian G61R, HD621, G55, MC200, MS600
Pioneer LX5090 Calibrated, Marantz UD7007, HIFi Racks Podium Reference
Monitor Audio GX100, GXC150, Apex A10, BK XLS400 (set with hard knee house curve)
Graham Slee Spatia (SC) Graham Slee Cusat 50 (IC x 5 Analogue,x 4 Digital)
WishTree
WishTree's picture
Recessed midrange is a big killer, for me Sad
The audition was at dealer's demo room and we immediately switched to KEF R100s in the same roon with some Marantz electronics and they did not have the recessed mid range any more.
Smile Luck is a phone call or a little bit drive away.. !! The only problem is resisting to temptation if they do live up to their excellent reviews.. and even better is I get to hear them at home so it would be no more blaming unknown electronics, unknown room acoustics!!!
__________________
My System  |
WishTree
WishTree's picture
I do believe in that as well and I will not give up.
Yes, I have PEQ in the CP-800 however these speakers were heard at dealer audition room and with R100s in the same room, they sounded alright..
I will keep an open mind on DSP!
__________________
My System  |
WishTree
WishTree's picture
Nick,
Thank you for the clarification. I am not aware / familiar with the Meridian house sound and if this is so, then I can rule out a brand completely!
I am looking forward for the Vivid Auditio and I really loved the sound of Kef 201/2 at home!
__________________
My System  |
ellisdj
ellisdj's picture
Meridian systems only use DSP / EQ in the bass region - there is a big article they have written why eq from bass up is bad - to do time domains etc.
I have not read it all - but these guys do know their stuff so I have taken on board their arguement.
I on the other hand firmly believe in Room equalisation as much for music and films - I am sure there is a valid reason why its bad, however I wouldnt dream of listening to a system now without it.
Therefore if you are used to hearing a system that has EQ - every system that is not EQ'd will sound off in regions / bad as they are likely nowhere near reference / flat curve (assuming thats what the Classe has done for you).
Therefore I am suprised you have gone now the active speakers route in the first place, room eq is missing from those options
I think its great that a Classe Stereo Preamp / processor has it in - normally eq is shunned by high fi brands.
Maybe the Meridian sound isnt for you - but your opinion of it is not 100% accurate the overall meridian sound - using a mac to feed it they would say would have a large negative effect - they would point you at a MC200 / MD600 Core / Storage to an MS600 then on again digitally to the speakers or out via the analogue on the MS600.
Check out these reviews
http://www.hifi-advice.com/Meridian-MD600-MS600-review.html
http://www.hifi-advice.com/Meridian-818-review.html
__________________
oldric_naubhoff
RE: re:
I know exactly what you mean. I don't have a huge living room but it's not puny either, approx 4,5m * 4m. my MG12s fit in quite OK. but I know that if I wanted to upgrade to a larger model (I think I'll make a jump straight to MG3.7, omitting MG1.7, not to mention that I'd like to try out a true ribbon model, my Magnepans are quasi ribbons) I'll have to upgrade my apartment too Smile.
that's not exactly what is my experience. if you give them about 3ft behind them they should be fine, but more is better. and in case of flat speakers 3ft is not such a bad thing. it's like you left 2ft behind typical box speakers, which is arguably the minimum clearance distance from back wall for typical box speakers. the front of both speakers will be more or less on the same plane.
the only thing where planars may cause more trouble is bass IME. every room will have resonances and anti-resonances in bass. and the only really good thing to fight them is to set up bass traps. I have a bass reinforcement in region of 40 - 50 Hz and then corresponding suck out around 100 - 150 Hz in my room. I'm getting a feeling that room nodes with MG12 are stronger excited than with Focus 110, which means the 40Hz resonance sounds more powerful and 100Hz region very lightweight in comparison. this on some bass heavy recordings gives strange tonality. it's like the lowest bass comes from a completely different set of speakers. but this is the only bad thing I can tell about MG12s. and it's not really the fault of the speakers but my room.
I also heard good things about Anthony Gallo speakers. good thing they use no xover. only mechanical attenuation between drivers apply. way to go Wish Tree! but I'm getting a feeling that comparing dynamic speakers, even from Gallo, to ESLs is a little bit far fetched IMO...
still, awaiting your report. Smile
__________________
Overdose
Overdose's picture
RE: Third time Active Speaker Disappointment
If you spent £4k on 'pro audio' instead of 'high-end', I reckon you'd hear a completely different side to actives. That sort of money would get you some very capable monitors indeed, with enough left over for a couple of screens to hide them. Wink
__________________
Mac mini > AVI ADM9Ts
WishTree
WishTree's picture
I might but I was constantly driven away sub consciously that pro audio is designed to show everything in the recording where as my hobby is only to enjoy the music at the highest quality possible / affordable. I might be wrong here but somehow pro audio equals to honest / analytical / unforgiving Sad
__________________
My System  |
WishTree
WishTree's picture
RE: re:
For me 3 feet behind the speaker front plane is not possible.. Once I move to the new place (in few months), I will post some pictures and I bet you will feel sorry for me for the smallness of the room Wink
At the moment I am into things which work on wall or placed close to the wall.
I never would think Stradas can be compared to ESLs however the 6moons review did that which is still surprising to me to the extent of I do not believe it !!
We will see as I will be getting the speakers in a week's time however I would still not be able to comment on the comparision to ESL as I never heard ESLs
One thing I am excited about Stradas are that they perform even better with closer to the back wall! What a bonus for a person who has such small listening space!
__________________
My System  |
WishTree
WishTree's picture
I understand EQ to some extent. Though the CP-800 has PEQ, I only used them with my previous speakers to tame the shoutiness. With the current R300s EQ is off.
Honestly just with AC200 and DSP 3200, if the Meridian system is not willing to work perfectly and needs an MC200 as well, then I am sorry.
My CP-800 accept the Mac Mini USB with out fuss and same goes with all the other DAC I had before. So it is purely irrational to me that though AC200 has USB input, it would not work with Mac Mini (which IMO has very good sound out of the box) very well and needs some more investment.
I give it to that what I heard might not be Meridian sound but what ever I heard was definetly not worth 5600 Pounds or even 1/3rd of it. Purely my view based on my audition.
__________________
My System  |
Overdose
Overdose's picture
I hear what you are saying, but you are largely at the mercy of the recording. If you start with a neutral and dynamic speaker, harsh recordings can be EQ'd to suit, that is afterall what a coloured system does, but with much broader strokes and to all recordings, as opposed to selected ones.
One mans meat is another mans cliche and all that, but I've yet to listen to anything that causes me to want to switch off the system. If I like a particular piece of music, I'd happily listen to it on a mono FM radio in the kitchen for example. The enjoyment is in the music, or at least should be. Too much angst is given out to making ones system sound just so. Such small degrees are easily dealt with via EQ.
You have a lovely looking and capable system, do you really need more? Always remember that everyones system is someones dream system.
__________________
