34 posts / 0 new
Last post
Callum J's picture
Last seen: 11 months 6 days ago
Marantz MCR610 and Spotify question.
Hi folks.
I wonder could anyone help me with a question i have?
I purchased the MCR 610 recently, and an enjoyable experience it is! I also subscribe to Spotify Premium, which is excellent, but a pain to search with the machine's remote, where you have to enter every letter via the keypad.
As i also have my PC in the same room, connected to the same BT Hub as the Marantz, is there a way to control Spotify on the 610 via the PC, rather than punching letters into a remote control. Or, put it another way, is there a method of getting the PC to talk to the Marantz?
I would be interested in any solutions to this query.
Thanks in advance
Callum.
chebby's picture
Online
Last seen: 1 day 16 hours ago
RE: Marantz MCR610 and Spotify question.
Callum J wrote:
Hi folks.
Thanks in advance
Callum.
Get the Spotify app on your smart-phone / tablet and use wi-fi (or AirPlay if you use an iOS device).
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
knaithrover's picture
Last seen: 2 weeks 4 days ago
I have the same issue and have got round it by running a HP Wireless set-up into the analogue AUX, not ideal but cannot get my PC to talk to my Marantz through WIFI directly. Agreed - The smartphone app is clunky as hell
Arcam Solo, Acoustic Energy 305, QED Uplay.
Arcam FMJ A19, Marantz CD6002, Monitor Audio RX1, Arcam Miniblink, Rega RP1 (upgraded). Pro-Ject Tube Box SE ii.
Tidal
Atacama, Grado, Sonos, Canton & Apple.
Callum J's picture
Thanks for the replies.
Just wondering Knaithrover....what exactly is an HP wireless set-up, and where do you source it?
I don't have a tablet, and don't fancy the smartphone option much, so that is why i'm trying to find a way for the PC to operate Spotify, as they are both in the same small room.
chebby's picture
Online
Doesn't your PC Spotify application have a wi-fi option? (I don't use Spotify but I assume it must have this ability. I thought it did everything on anything.)
MajorFubar's picture
Last seen: 5 days 14 hours ago
Don't think so Chebby, unless you're running it on a recent Mac which supports Airplay audio transmission. OP is using a PC so that's out.
He needs some software on his PC which sets up Airplay as a 'virtual' sound card/output device. Not sure if there is such a thing? It would surely need to be Apple-licenced.
EDIT wait a mo, what about AirParrot? Or does that only do screen-mirroring and not audio  :?
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or Audio Technica ATH-M50X
Hi Callum - HP Wireless audio is a usb dongle transmitter which is pretty good sound-wise and is dirt cheap now - look on Amazon i got my 2 for around £25 each (they were originally £150 i believe) There are also loads of these on ebay if you prefer that route.
Tidal
DocG's picture
Last seen: 1 day 17 hours ago
How far is your PC from the Marantz? Maybe you can use a USB-to-SPDIF converter, and plug the PC in a digital in (PC - USB-cable - converter - coax-cable - Marantz coax digital in). You can then run Spotify on the PC and use the Marantz as an outboard soundcard. These converters can be had for less than $20 a piece on the Bay.
Downstairs: Bluesound Node2 -- DEQX HDP-3 -- 4 x Hypex NC-400 -- modded Magnepan MMGs
Upstairs: NAD M50 -- Devialet D120 (SAM) -- KEF LS50
Head-fi: in progress...
Callum J's picture
Thanks for the replies, it gives me something to think about. My pc is about 4 metres from the Marantz. Will that be too long a stretch?
DocG's picture
No, that's doable. A USB cable works up to 5 m length. I'm not sure on coax SPDIF, but I think it can handle even longer runs (and optical SPDIF easily takes 100 m). So you could choose to put the converter next to the PC or hide it behind the amp. I assume the long USB cable will cost you less than a long SPDIF cable (but I didn't check that).
Upstairs: Nad M50 -- Devialet D120 (SAM) -- KEF LS50
Callum J's picture
Thanks Knaithrover and DocG for your helpful replies. I'm very interested in both replies, but i'm afraid, (not being up to speed on that kind of technology), to being a bit baffled as to how exactly these things work, and which of them would best suit my needs? Do they affect the sound quality of the Marantz in any way?  Can i just open up Spotify on my PC and browse for artists, songs, and albums, select a track or playlist, and then click on play, and then the Marantz just fires up and does it's thing as it would using the supplied remote control? or is it a bit more complicated than that?
Callum.
DocG's picture
I think both options would work very similarly. You need to:
- open Spotify on your PC and select what you want to hear
- fire up the Marantz, choose the correct input and set the volume
BTW, Spotify has far more interesting features on PC than in the Marantz app (like radio function based on a song, album or performer to name just one)!
IMO a wired connection is more robust, but wireless transmission can be a very elegant solution too. Up to you!
EDIT: the sound quality (of both options) should be very comparable to other digital inputs, as it is the MCR610's DAC that does the digital-to-analogue conversion. With a less than optimal wifi you have the risk of drop-outs (short stops in the music), but with just a couple of metres between the dongle and the amp, that shouldn't be an issue. But as I said before, the wired connection is more robust (by design).
DM_London's picture
Last seen: 3 years 1 day ago
Premium spotify users have or should have something called spotify connect. This feature lets you control what your active device plays from another device which has your spotify account. Eg you fire up the marantz and start playing a spotify track. Then log into your PC spotify account, change the song and the marantz should automatically change. There should be a green icon at the bottom of the screen. I discovered this recently (iPhone vs IPad) and it was brilliant. I've connected my iPad to my marantz cd6005 via USB and control my playlist via iPhone - thereby benefitting from marantz dac and wireless convenience. Clever app...!
davedotco's picture
Last seen: 1 week 23 hours ago
I think this is exactly what the OP wants.
Can you explain in a bit more detail just how you make that work.
DM_London's picture
Did some more searching - seems that desktop based spotify connect is not yet live - will be soon though. Definitely works on mobile devices - but you would need two devices to make this work eg iPhone + iPad.
Callum J's picture
This sounds really interesting, wonder when it will become live for PC?
Pages
Log in to post comments
