17 posts / 0 new
Last post
lpv
lpv's picture
Last seen: 5 hours 46 min ago
Marantz M-CR510
...seems like something I've been waiting for - at least from the specs.. slim design so I can fit it on my shelf and full tone control from the handset.. is it right move from my PM6004 and Arcam rDac in terms of sound quality?
ID.
ID.'s picture
Last seen: 1 week 19 hours ago
RE: Marantz M-CR510
Too new, so you might not get many (any) answers with 1st hand experience, but going by the M-CR603, it would be a step down in terms of sound quality.
Now if you put better speakers on the end of it it may well outperform your current kit, but so would putting better speakers on your kit (up to a certain point).
Machinemessiah's picture
Last seen: 10 months 2 weeks ago
RE: Marantz M-CR510
What would you recommend as a speaker upgrade?
Pure Audio i dock, Primare Pre32 MM30, A34.2 power amp, Sonus Faber Venere 3.0
Cypher's picture
Last seen: 3 months 2 weeks ago
RE: Marantz M-CR510
I would keep the PM6004 and rDac for sure. The M-CR510 looks nice but the sound will disappoint you.
utomo's picture
Last seen: 5 months 2 weeks ago
RE: Marantz M-CR510
By looking at the spec it is good enough.
it has good power 2x 60 W, compared to other denon, and onkyo around 2x 30W
It has built in WiFi and other features.
I hope the sound is good.
But we also need to wait what Onkyo and Denon new models will offer.
I hope Micro system have Internal Harddisk for storing the music. Instead of external harddisk which not so good ideas for compact products
just my 2c
lpv
lpv's picture
RE: Marantz M-CR510
Thanks for your answers.. I'll wait then until M-CR510 hit the dealers.
utomo's picture
RE: Marantz M-CR510
Mostly whathifi will suggest Q accoustic 2020i
if you want better ones try q accoustic concept 20
BigH's picture
Last seen: 1 month 6 days ago
RE: Marantz M-CR510
Kef R100.
Listen to the music, not the hifi.
manicm's picture
Last seen: 1 day 16 hours ago
RE: Marantz M-CR510
No it won't, Marantz website states it has exactly the same amp as the new M-CR610, the same 60w. It's just a pure digital stripped down 610 i.e. no CD player, no FM.
utomo's picture
RE: Marantz M-CR510
@manicm
ID mean step down from current PM6004 and Arcam rDac.instead from the 610.
But we did not know because both not yet available right ?
magnus78's picture
Last seen: 2 years 1 month ago
RE: Marantz M-CR510
I'm eyeing at the M-CR610 as i need the cd player. Just need to wait for review whether it sounds better than the 603.
ID.
ID.'s picture
RE: Marantz M-CR510
utomo wrote:
@manicm
That's right. Because it is a step down in sound quality from the 6004 to the 603, I'm assuming that it will also be a step down in qualify going from the 6004 to the 610 or 510.
utomo's picture
RE: Marantz M-CR510
I hope you are wrong.
Because This year is Marantz 60 Anniversary, They must producce good products.
If not they will need another 10 year
http://www.whathifi.com/review/marantz-pm6004
only 2x 22,5 watt
No USB
No Pre out
NO FM, No DAB
No Internet radio
I will wait to see newer products
ID.
ID.'s picture
RE: Marantz M-CR510
only 2x 22,5 watt
No USB
No Pre out
NO FM, No DAB
No Internet radio
2x45 at 8 ohm. 60 at 4 ohms and in general the fact that it doesn't have those other functions means that more resources have been allocated to towards achieving better sound quality.
If you want those functions you might have to compromise on sound quality a little or aim for a more expensive product.
That's the theory at least.
malifact's picture
Last seen: 2 years 6 days ago
RE: Marantz M-CR510
Unless one really doesn't need CD function, the M-CR610 seems a better deal for just £100 more.  I'm expecting both new models to sound similar to the M-CR603, as Marantz haven't given any indication that the sound will be drastically different.  Which is not a bad thing as the M-CR603 sounds great.
I wonder if Denon and Onkyo will be upgrading any of their all in one systems. I would seriously consider an upgrade of the Onkyo TX-8050 if it had gapless playback.
manicm's picture
RE: Marantz M-CR510
ID. wrote:
utomo wrote:
@manicm
If you agree that the 610 is no step down from the older 603, then the new 510 is equally good as it has precisely the same amplification as the 610, the new models are on the Marantz website, if you'd care to look.
Pages
Log in to post comments
